compression test results
Old Jul 23, 2002 | 07:40 AM
ITR21's Avatar
Default compression test results
i just did a compression test on my ITR and it came out 210 psi dead on in all 4 cylinders. Is this about average. What have you been getting?
Old Jul 23, 2002 | 07:46 AM
FSTASNTZ's Avatar
Default Re: compression test results (ITR21)
Remember that your readings may be higher or lower than someone elses due to differences in gauges and attachments.
As for 210 across all 4, sounds great to me. You are looking for consistancy across all 4, not necessairly high numbers...
Jason
Old Jul 23, 2002 | 07:51 AM
BlueR's Avatar
Default Re: compression test results (FSTASNTZ)
mine was 210, 211, 210, 220....
and everybody said they were fine so....
Old Jul 23, 2002 | 08:07 AM
AllMotorMadness's Avatar
I did one on my friend's 2001 itr showed 230psi across all four cylinders. Stock Head stock block
Old Jul 23, 2002 | 08:10 AM
typer_801's Avatar
Default Re: compression test results (BlueR)
I had 210 across the board on my 98R as well and was told it was good as well.
Old Jul 23, 2002 | 08:30 AM
Razor's Avatar
Default Re: compression test results (AllMotorMaddness)
230 is a little high for a stock itr. 210 is the average compression i've seen on stock itr's at the local shop.
dazcivic
Aug 21, 2009 07:02 AM
willah
Jan 10, 2005 04:59 PM
Mr.Integra
Apr 28, 2004 05:47 AM
Norcalstoppy
Nov 21, 2002 12:55 PM
