No Power - 89 HF - Need Help
Old Aug 14, 2008 | 03:11 PM
Raysp30's Avatar
New User
Default No Power - 89 HF - Need Help
I've only had this car a few weeks and I'm still getting everything fixed on it. I'm completely stumped right now. When the key is on Acc, there is power, and sometimes that power is not steady (the radio will blink on and off over and over). When the key goes to the on position, everything goes blank -- no power. Needless to say, when I turn the key nothing happens.
I am 95% sure this is an electrical issue. Any idea what it might be?
Old Aug 14, 2008 | 04:10 PM
scottmog's Avatar
Default Re: No Power - 89 HF - Need Help (Raysp30)
it may be a battery. just enough juice to get the radio on but not enough to get the car starting
Old Aug 14, 2008 | 04:38 PM
vtecb18c's Avatar
Default Re: No Power - 89 HF - Need Help (Mog)
check for any loose ground wires expecialy you negetive terminal on the battery
Old Aug 14, 2008 | 05:16 PM
Raysp30's Avatar
New User
Grounds are all fine. So is the battery. It's something related to the ignition.
Key in Acc, limited power, key to on and everything instantly goes black. When the key is on acc. there are no lights on the dash like you normally have when you put the key in.
Old Aug 14, 2008 | 06:14 PM
Raysp30's Avatar
New User
Default Re: (Raysp30)
I still think it's something with the ignition. Key in postion 1 with the hazard light switch on and it makes a siren type buzzing sound along with the beep that comes on when you don't have your seatbelt buckled. Same thing with key in position 2 and everything is out.
Could this be the ignition starter switch?
The only other thing I can think of is a bad main relay?
Old Aug 14, 2008 | 07:41 PM
scottmog's Avatar
when u go to position 2 u should hear two sounds.
sound number one: humming sound while the check engine light is on (about .5 seconds long)
sound number two: a loud click
one = fuel pump
two = main relay
if u are getting that click then count your relay out, its still fine.
Old Aug 14, 2008 | 07:47 PM
S.Stenger's Avatar
my buddy put an ignition switch in a crx that had the same problem
Old Aug 14, 2008 | 09:47 PM
armerwandrer's Avatar
Default Re: (S.Stenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S.Stenger &raquo;</TD></TR><TR><TD CLASS="quote">my buddy put an ignition switch in a crx that had the same problem</TD></TR></TABLE> X2 Its a common problem. Jiggle or slightly turn the key a little when it happens and see if it either helps or makes it worse. Either way you need one. DON'T put one in if it doesn't affect it at all. The dealer should even stock it even though it is almost 20 years.
eric p
Sep 18, 2013 11:17 AM
4drctr420
Honda Civic (2001 - 2005)
Dec 6, 2011 02:10 PM
CTR LOVER LU
14
Mar 23, 2010 08:36 PM
upallnite
Dec 27, 2008 06:59 PM
