code 17 (vehicle speed sensor) ???
hi im from city of juarez in mexico is the border line with el paso texas, my english isn't good but here i go, my friend has a 1989 CRX and i got de codes because the chek light its on, and the led gave me 17 short flashes, i don't know if that means code 17 cus that is (vehicle speed sensor) and i don't know what and were is it,
well my short experience in honda's tell me if is the code 17 the problem had been 1 long flash (thats mean 10 rigth?) and 7 short flashes, no? well if some body can help me i'll be very thankfull!! sorry i forgot its a Si with 1.6 liter and manual transmission!!
If you get 17 short flashes without pause then yes, it is a code 17.
Check the speedo cable. If the speedometer is not working, then you'll get that code.
yea if your MPH on the cluster dont move or bounce around then its your speedo cable. pin could have slipped out or their might not be one or the cable is just old and gave out.if so its located on the tranny and very easy to fix.
I had this same problem. It's a intermittent code on my car. I removed the hazard fuse and cleared the code and haven't seen it since. If it's not the cable it's probably the speedometer assembly. Your english is better than Mexicans that live here.
From: I told you to wait in the truck in Texas, United States
Look here toward the bottom for pics:
https://honda-tech.com/zerothread?id=1325930
I have a question, How can I easily remove the sensor from the tranny? I have an 88 Crx and It seems almost impossible to remove it. My speedometer stopped working so I checked behind the cluster to see if it was still connected and it was. So I'm thinking that maybe my sensor is bad? Or wire is broken? I want to remove it but I can't quite get my hands to it... Any ideas?
i dont have any pics, but the speedo cable goes into the top of the vss, there is a little boot on it pull the boot up and remove the little horse shoe shaped clip. pull the cable out, give it a little tug and see if the cable is broken. if not there is a little 10mm bolt that holds the vzz in the trans remove that, and carfully twist the base of the vss back and forth with a upward motion.
any more questions please ask ok.
p.s its not really a sensor so to speak, its really a gear that rides on the differential
do I have to unbolt anything before pulling the wire up? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepingciv »</TD></TR><TR><TD CLASS="quote">i dont have any pics, but the speedo cable goes into the top of the vss, there is a little boot on it pull the boot up and remove the little horse shoe shaped clip. pull the cable out, give it a little tug and see if the cable is broken. if not there is a little 10mm bolt that holds the vzz in the trans remove that, and carfully twist the base of the vss back and forth with a upward motion.
p.s its not really a sensor so to speak, its really a gear that rides on the differential </TD></TR></TABLE>
At the transmission,pull the inside completely out of the housing:
The entire inner cable should be 34 3/4" long..
If not,it is broken..
If the cable is in one piece,Grease it up and stick it back in the housing:
The green line should be inserted all the way to where the slot is:
It is then held in place with the clip which is usually found inside the rubber cover:
You may have to turn the cable until it lines up with the drive in the sensor...
If you are trying to remove the speedo gear drive:
If you have access to compressed air,use a blower nozzle
to blow out any sand/debris around the top where it goes into the case.
Soak the area liberally with a penetrating oil like PB Blaster..
Lock a small pair of vise grips around the lower larger portain of the sensor
And then work the sensor from side to side to break the seal of the internal o-ring
After the seal is broken,it should pull right out...
ServiceAdvisor
Jun 14, 2004 05:40 AM
