CRX Tranny fill bolt
Does anyone have a handy picture of the fill bolt on a 90 crx dx? I am not quite sure which one I have to remove in order to fill the transmission.
Thanks.
Thanks.
it's on the side of tranny near the axle, a 17MM bolt with a much larger base (the hole is probably 22 MM that it threads into) Fill until fluid comes out the hole and cap it off, you're done.
I usually take my starter off n there is a 17mm or 19mm bolt under the starter. There will also be a spring so watch it dont lose it. Fill it through there a lot easier then having to stick a hose on the hole on the side of the tranny. Now u still take off the 17mm bolt on the side to tell when it is full. Sorry dont have a pic.
#11 is the fill bolt. use a 17mm 6 point closed end wrench. do not attempt with a 12 pt! it is a tough bolt to remove and even a 12pt wrench will strip it. so i recommend removing that FIRST, before draining the tranny.
#7 is the drain plug. use a 3/8 ratchet to remove it.
I like using the reverse hole.. Right in the open. Its number 6. I believe 19mm wrench? Thats where I fill up my fluids at. Oh ya, its 2 1/2 quarts to fill the tranny. If it already has some fluids... Be sure to check the check plug after you fill.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">2.5qts is too much.
do it right with the fill bolt and youll see its just below 2 qt.</TD></TR></TABLE>
2slow4stock is correct. It says in the manual that it takes 5.0 pts.
5.0 pts = 2.5 qts
But that is when there is no fluid at all. Like the engine oil there is always fluid left in there.
5.0 pts = 2.5 qts
2.1 qt at assembly.
1.9 qt at oil change
YOU stand corrected.
http://media.honda.co.uk/car/o...2.pdf
I never said that Tyson was wrong. Did I ever say that?
What I was talking about was the full capacity of the tranny when its totally drained. Did you not read all of my post? I was saying that its never going to take the full amount unless you're doing a total rebuild or something.
The information that I got came from a Chilton Manual. So don't say you corrected me when that's what the manual says and not me.
Modified by meandino at 5:01 PM 8/17/2008
its 2.1 qt at assembly, fully drained. not 2.5 qt. you are wrong for posting incorrect info from chiltons. 2slow4stock is NOT correct either. just getting the facts straight.
-1 chiltons.
+1 honda fsm aka helms.
-1 chiltons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">-1 chiltons.
+1 honda fsm aka helms.</TD></TR></TABLE>
LOL Chilton manual has so many errors.
#9 is also a fill bolt. just gotta take out the battery.
</TD></TR></TABLE>#9 is also a fill bolt. just gotta take out the battery.
Tyson is correct. When I had reassembled my transmission, it took about 2qts. No way 2.5 would fit unless you fill through the VSS with fill bolt tightened.
Now on the other hand, the 92-00 D-series transmissions DO take more fluid(around 2.5qts IIRC); which may be where the discrepancy came from.
doom26464
Jun 18, 2008 07:10 PM
inscape
Jan 21, 2005 12:27 PM
Mackenzie
12
Oct 30, 2004 07:49 PM
asubennett
Aug 21, 2003 05:14 PM
