TOP 5 SECURITY TECHNIQUES
Old Aug 13, 2008 | 09:30 PM
taimysho0's Avatar
Default TOP 5 SECURITY TECHNIQUES
hey guys, i know that if a thief really wants to steal a car, he or she will try to get it. but, the only thing the owner can do is to delay the thief with several security techniques. what would you say is the top 5 ways you can prevent your car from getting stolen?? btw does any1 have any info on gps tracking devices? thanks!
Modified by wrx-killer-Sti-eater at 10:49 PM 8/13/2008
Old Aug 13, 2008 | 09:47 PM
Green2000CivicEx's Avatar
Stealth installed alarm system with tilt sensor and battery backup siren.
Lojack (or similar system)
Hidden starter and ignition kill switch.
Opened condoms all over the seats and gay porno mags.
Handgun in your nightstand.
Old Aug 13, 2008 | 10:41 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (Green2000CivicEx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green2000CivicEx &raquo;</TD></TR><TR><TD CLASS="quote">Stealth installed alarm system with tilt sensor and battery backup siren.
Handgun in your nightstand.</TD></TR></TABLE>
Lo-jack as a layer, Remember lo-jack is a beakon and not gps
Dei- 210c or 210v gps tracking system- you know were the car is all the time plus e.w.s. The dei gps unit call your cell or any number program to it withen 15 secs to 1 min of the alarm being triggred. You WILL KNOW WHEN A THIEF IS MESSING WITH YOUR CAR. It takes more then a min to even try to steal a car with a decient alarm system. If at all.
Main relay kill, The fuel kill has become too popular with car owners and theives. Now they just go straight to your fuel pump with 12 volts. This will bypass all fuel kills no matter were the switch is. So just use a fuel kill as a layer. The main relay kills the fuel pump, injectors an part of the ecu. So its three in one kill switch. Even if they hit the fuel pump with 12 volts the car will not start. You can't hot wire injectors. Use this set up and relocate the main relay so it can not be tampered with. 100% there not going to drive away.
Stop putting the dam siren in the engine bay. So a theif can pop the hood and cut it and work in silence.
Right way
Stop and don't let any installers do this to your car.
or this
or this
or this
or this
close but still no cigar
This is the best way, Sorry, I can't show you were the brain is but you get the picture, there is plenty of room
or basic like this
All alarms should have a back up battery and a hood pin. I say all should have some sort of tracking system. But Some can't afford it or its out there budget. Most if not all the thefts on here could been avoided. I feel if you dump 4k plus into a new swap, rims or any other mods why not start with security first? So a theif can watch you build their next target or new toy. Once people wake up and figure this out there will be no more thefts. Its not the theifs fault that he took your car. Its his dumb broke azzzzzz job. Its your job to secure your car. If you read this you need to go look under your dash and compare with the pictures up top. If you match the bad ones you need a new game plan.
Old Aug 14, 2008 | 06:40 AM
B18C_EJ8's Avatar
Sure, LoJack's great if you happen to live in one of the few cities in the US that there's service in.. For the other 95% of the country, it's a waste of money...
Old Aug 14, 2008 | 02:51 PM
Tekkaboy's Avatar
Default Re: (wrx-killer-Sti-eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti-eater &raquo;</TD></TR><TR><TD CLASS="quote">
Right way
I hope that hood release cable was later relocated to inside the bay!
If you really want to be secure,
Layers
Don't leave valuables visible (including expensive seats, stereo, etc.)
Park in areas with lots of foot traffic
GPS Tracking system
Put a parking boot on your car
Modified by Tekkaboy at 3:58 PM 8/14/2008
Old Aug 14, 2008 | 03:03 PM
tha_badguy's Avatar
re-routing ur hood release isnt needed when ur tuckin tire...
Old Aug 14, 2008 | 03:22 PM
Default Re: (tha_badguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">re-routing ur hood release isnt needed when ur tuckin tire...</TD></TR></TABLE>
How is that unit working for you? hint nint
Old Aug 14, 2008 | 04:42 PM
nsxxtreme's Avatar
me thinks that you cut the wheel liner out and that siren is toast.....Hope you got more then just that siren.
When I had an integra I cut the wire at the distributor. So if they killed they alarm they lost power to the distributor.
Old Aug 14, 2008 | 05:52 PM
Default Re: (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">me thinks that you cut the wheel liner out and that siren is toast.....Hope you got more then just that siren.
When I had an integra I cut the wire at the distributor. So if they killed they alarm they lost power to the distributor.</TD></TR></TABLE>
Nope, you can't reach it with the fender liner cut and the wheel straight. And you can't unbolt it or break it. Nor cut the lead wire. You dam sure can't get it with the car being lowered. I test out everything before I offer it to the public.
Old Aug 15, 2008 | 07:51 AM
nsxxtreme's Avatar
You don't actually have to physically "get" to the siren. I have seen a tool that they use. Its basically a long bar kinda like a scissor jack handle but flexible that has a hook on the end. The slide it in grab the wire then turn until it rips the wire out. This is how a lot of them get under the hood an disconnect the siren without setting the alarm off. They just pry the hood up then slide this thing under.
And if I remember right on that integra the wheel liner goes over the wheel then under the front bumper. Relatively easy to cut the wheel liner near the bumper out. Not to mention cutting through that front bumper is EASY!!! that how a lot of them unlock the hood. Cut right through and get to the latch.
Another thing I have seen them do is if they can't get to the wire they will attach one of those siren covers that are in alarm stores so they siren is not so loud. Or spray expanding foam up in it. Just saying seems relatively accessible from the outside. I would hope that is not the only siren. Never underestimate the ingenuity of a thief.
Modified by nsxxtreme at 8:57 AM 8/15/2008
Hardedge
Audio / Security / Video
Oct 6, 2007 09:21 PM
91DroppedHatch
Jun 17, 2005 01:31 PM
I Gotta Question
Jan 26, 2004 07:33 AM
cstem
Nov 27, 2003 06:03 PM
threatcon13
Jun 9, 2003 07:03 PM
