1995 Civic EX.....NO SPARK....What does code #15 (Ignition Output Signal) MEAN?? Help.
Old Aug 13, 2008 | 05:51 PM
toddcoggins's Avatar
Default 1995 Civic EX.....NO SPARK....What does code #15 (Ignition Output Signal) MEAN?? Help.
I have a 1995 Civic EX with a 1.6L. The car just turns over and turns over without catching. The car has no spark whatsoever, I have tried a new distributor that did nothing and I have a buddy at a salvage yard and tried a new ECU that did nothing. I just learned about the diagnostic check and performed it, I got code number 15 Ignition Output Signal, what does this mean? Is it the ignition switch? I have looked into them and they seem to have to be purchased as a whole unit, are they complicated to install? Anyone that knows please lend me a hand and let me know what this code means. Thanks alot.
Old Aug 13, 2008 | 06:44 PM
taztwnpa's Avatar
Default Re: 1995 Civic EX.....NO SPARK....What does code #15 (Ignition Output Signal) MEAN?? Help. (toddcogg
try,
Go here: http://www.hondahookup.com/manuals/
I found another web page that walked you thru diags of the system to pin down problem. But I can't find link.
Old Aug 13, 2008 | 06:53 PM
95dxsir2's Avatar
don't just start replacing ****.
i believe it's the wire coming from the ecu to icm.i'll check.
Check and see if there is voltage on the blk/yel wire @ the dist.
Modified by 95dxsir2 at 7:58 PM 8/13/2008
bpowa
Oct 26, 2009 07:13 PM
dhernandez_9117
Oct 13, 2009 06:29 AM
i hate import cars
Oct 21, 2008 12:34 AM
90crvtec
Aug 19, 2005 07:19 PM
jonathancrx
Mar 19, 2005 01:33 AM
