1995 Civic EX.....NO SPARK....What does code #15 (Ignition Output Signal) MEAN?? Help.
I have a 1995 Civic EX with a 1.6L. The car just turns over and turns over without catching. The car has no spark whatsoever, I have tried a new distributor that did nothing and I have a buddy at a salvage yard and tried a new ECU that did nothing. I just learned about the diagnostic check and performed it, I got code number 15 Ignition Output Signal, what does this mean? Is it the ignition switch? I have looked into them and they seem to have to be purchased as a whole unit, are they complicated to install? Anyone that knows please lend me a hand and let me know what this code means. Thanks alot.
Re: 1995 Civic EX.....NO SPARK....What does code #15 (Ignition Output Signal) MEAN?? Help. (toddcogg
try,
Go here: http://www.hondahookup.com/manuals/
I found another web page that walked you thru diags of the system to pin down problem. But I can't find link.
don't just start replacing ****.
i believe it's the wire coming from the ecu to icm.i'll check.
Check and see if there is voltage on the blk/yel wire @ the dist.
Modified by 95dxsir2 at 7:58 PM 8/13/2008
dhernandez_9117
10-13-2009 06:29 AM
i hate import cars
10-21-2008 12:34 AM
