B18 build Help!
Old Aug 13, 2008 | 05:14 PM
hpimichael02's Avatar
Default B18 build Help!
hey guys,
i have paid for a B18b1 block and head, and i would like to do a B18B Pure motor upgrade.... its going into a 98 DC ls
i was gonna get the b18b1 block with the new head,
and use:
Eagle 4340 Forged Steel Crankshaft
Eagle 4340 Forged 3-D H-Beam Rods with ARP rod bolts
SRP Forged Pistons
Piston Wrist Pins, Locks and Piston Rings included
ACL High performance bearings
CROWER TWIN CAMSHAFTS stage 2
OMNI POWER VALVES
ti retainers
Dual valve spring
end result 11.3/1
this a good setup?
This is my daily driver, my current engine has 148,000miles....
Old Aug 13, 2008 | 05:25 PM
vtecb18c's Avatar
Default Re: B18 build Help! (hpimichael02)
thats a descent setup for an LS...i think your compression will be almost perfect for BCs2 cams....keep us posted on the build
p.s- if the crank is in descent shape i wouldnt replace it, LS cranks are known to hold up when producing good numbers....i just hope your not expecting crazy N/A numbers like a lot of p eople do
Old Aug 13, 2008 | 05:40 PM
Default Re: B18 build Help! (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">thats a descent setup for an LS...i think your compression will be almost perfect for BCs2 cams....keep us posted on the build
p.s- if the crank is in descent shape i wouldnt replace it, LS cranks are known to hold up when producing good numbers....i just hope your not expecting crazy N/A numbers like a lot of p eople do </TD></TR></TABLE>
ohh yea man i was hoping to get atleast a 180 HP gain
HAHHHAHAHA no i just want it around total 165-170hp ... cause the cams should give you around 15 hp there, and high comp should give atleast another 10-15hp.. the block doest have a crank.
where is a good place to get all my engine bolts and what not to put it back together, since its a raw block, and can i reuse the bolts on the head??
Mike
Modified by hpimichael02 at 6:55 PM 8/13/2008
Old Aug 13, 2008 | 06:03 PM
vtecb18c's Avatar
i always get all my missing misc. things from honda(bolts,nuts,washers,ect...)...i only do that to ensure that im getting the right **** ya know?...which bolts are you talkin about the head studs? you can reuse those just make sure you torque them to specs
Old Aug 13, 2008 | 06:16 PM
is there an engine diagram, or blue print out there???
Old Aug 13, 2008 | 07:02 PM
Egezzy's Avatar
Spongebrad Squarepants
thurr is prolle one n the haynes manual u can get at autozone. .etc. .if not check google. .if u plan on doin it urself do research first!!
Old Aug 14, 2008 | 03:52 AM
Default Re: B18 build Help! (Egezzy)
can i put in pistons that belong to an ITR even tho its gonna be an built LS??? and yes it will be bored and hone'd(probly will be bored to a 2.0)
Prozon
Jun 21, 2011 09:01 PM
Tman6925
12
Dec 3, 2008 09:28 AM
hpimichael02
Aug 13, 2008 02:19 PM
seanc520
Oct 17, 2006 06:08 PM
MaxBoost
20
Jul 7, 2003 11:50 PM
