car wont run right wen drivin help urgently
Old Aug 13, 2008 | 04:28 PM
robby86's Avatar
Default car wont run right wen drivin help urgently
wen driving my lude it splutters. been doin this for week or so. tonight wen coming home the car started spluttering and turning of. could this be a loose wire dirty petrol? wot shud i do to start problem solving help asap please
Old Aug 13, 2008 | 05:32 PM
khooper's Avatar
Default Re: car wont run right wen drivin help urgently (robby86)
It would seem that you have various electrical problems and it would do no harm working through all connections and refreshing them with particular attention to the earth straps on the engine and battery to boot. I would of thought that it sounds like a fuel problem and it may be worth investigating the pump. You don't mention the sparkplugs or HT leads and as you've just got it it will be worth changing these as a matter of course. Otherwise you sound as if you've got a good handle on what you can expect, it will just take a little time and methodical process to get it perfect.
______________________________
Have a spot on Autopartswarehouse
Drive Safely and Move Freely.
Old Aug 13, 2008 | 07:21 PM
vtecb18c's Avatar
Default Re: car wont run right wen drivin help urgently (khooper)
sounds like you just need a tune up...plugs,cap,rotor,wires...ect...how many miles do you have on it? better yet, whens the last time a tune up was performed if ever?
Old Aug 13, 2008 | 08:00 PM
m00nr0ck Si's Avatar
Default Re: car wont run right wen drivin help urgently (vtecb18c)
Does it throw a check engine light (cel) ?
could be
*fuel filter
*fuel pump
*distributor
*ECU
*Clogged catalytic converter
just some ideas
Wyatt87
Feb 27, 2012 11:14 AM
Naiyasin
14
May 4, 2010 09:09 AM
jaydm ferio
Dec 8, 2006 11:27 PM
egcivic
Nov 24, 2006 02:53 AM
peteysmoooooth
Dec 2, 2004 10:39 AM
