hydro to cable transmission
Old Aug 13, 2008 | 03:30 PM
esean93's Avatar
Default hydro to cable transmission
so i have a eg nd im planning to put in a obd0 zc with cable tranny so watd i need to do to make it work?
Old Aug 13, 2008 | 03:59 PM
superfast666's Avatar
Default Re: hydro to cable transmission (esean93)
rethink this and dont
Old Aug 13, 2008 | 04:28 PM
esean93's Avatar
Default Re: hydro to cable transmission (superfast666)
ya i think ill just buy the zc nd get a hydro si or ex tranny!or do u mean rethink buying the obd0 zc?
Old Aug 13, 2008 | 04:46 PM
dapek's Avatar
check hasport for the hydro to cable mount but your def gonna need more shiz than that my deuce cents, just get a hydro tranny it'll be a little less of a headache for you
Old Aug 13, 2008 | 04:51 PM
Default Re: hydro to cable transmission (dapek)
if you get the zc obd0 you can make it obd1 by just changeing the intake manifold dizzy and injectors
Old Aug 13, 2008 | 05:06 PM
esean93's Avatar
yeah im goin with a si or ex tranny(hydro)
Old Aug 13, 2008 | 05:07 PM
good choice
Old Aug 13, 2008 | 05:09 PM
esean93's Avatar
well im going to use the dizzy from my dx but do i necessarily need injectors nd a intake manifold?watd i hav to do to make it work?
Old Aug 13, 2008 | 05:18 PM
B18C5-EH2's Avatar
Former Moderator
Loved
You can't use the dizzy from your DX on a ZC engine - it doesn't bolt on.
You need THIS
OBD1 ZC distributor from Distributor King.
Question:
Why not just buy an OBD1 ZC to begin with?
Old Aug 13, 2008 | 05:26 PM
esean93's Avatar
Default Re: hydro to cable transmission (B18C5-EH2)
well im getting a pretty good deal nd it only has 30k miles on it.tom from hmotorsonline told the him.looking at the price of the dizzy i guess i shld just go with a obd1.do any other dizzies bolt on to the zc?o nd is there any way i can make the zc fuel injectors nd intake maniforld work?
Old Aug 13, 2008 | 05:30 PM
B18C5-EH2's Avatar
Former Moderator
Loved
There is not another distributor that will work for you other than the one I linked for you, which IMO makes buying a OBD0 ZC engine pointless due to the price of the OBD1 dizzy, and the fact that you'll need to swap injectors for OBD1s, and there will be other differences like MAP sensor, etc.
Old Aug 13, 2008 | 05:38 PM
esean93's Avatar
yeah ur rite i almost bought the motor nd thought itd be better to research all this before i buy it.greatly appreciate everyones input!thnx
Old Aug 13, 2008 | 05:57 PM
B18C5-EH2's Avatar
Former Moderator
Loved
That's what we're here for bro!
Good luck!
H Motors Online is still a great place to buy the OBD1 ZC swap too though - last time a customer of mine bought one it even came with the correct ECU (P29 I think - it was a few years back) which most places don't even bother giving you.
If you cannot find one with an ECU then an OBD1 PR4/P75 works too. Even the 92-95 Civic DX P06 works well too. Ideally if you cannot find the correct ZC ECU with the engine you could get a P06 92-95 DX ECU rechipped.
Old Aug 13, 2008 | 06:07 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">There is not another distributor that will work for you other than the one I linked for you</TD></TR></TABLE>
Your not wrong on that, but if you happen to be broke/desperate enough you can get a D15B7 distributor to work. It goes like this, get the cam cap off a B18A1 and replace the ZC cam cap with it. this puts the top distributor hole lower so you can actually get one bolt in. You wont be able to set the timing, but it will run ok, not optimally but not bad either. A friend of mine bought an OBD1 ZC with a bad distributor and we couldn't figure out what to do, then he started eying up the B18 he had in the corner... anyway it worked.
Old Aug 13, 2008 | 06:14 PM
esean93's Avatar
do u work at hmotorsonline?i just called em they said they r out of stock but new supplys comming in 2 weeks.shipping quite alot though like 300 cuz i live in fl.
Old Aug 13, 2008 | 06:17 PM
esean93's Avatar
Default Re: hydro to cable transmission (94EG8)
naa too many unnecessary complications already.ill just buy a obd1.thnx though.
c0nspire
Transmission & Drivetrain
Nov 13, 2008 06:17 PM
shonbz
Mar 13, 2006 09:51 AM
91whiteZCrex
Jul 25, 2005 05:44 PM
RedlineUBRF
10
Apr 27, 2002 12:39 AM
