Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2008 Accord V6 - right rear body seam - FIXED WITH FOAM?
Old Aug 13, 2008 | 12:45 PM
rodmanhonda's Avatar
Default 2008 Accord V6 - right rear body seam - FIXED WITH FOAM?
I don't know how to start so I will just post the repair order narratives and hope to get some response:
<U>12/13/07 </U>- There is rattle/knock coming from the right rear when starting or stopping. also with body flex (turning). Body seam at right rear jack point causing knocking noise. performed repair procedure per techline engineering ref#2511212. replaced left rear sway bar end link
<U>4/18/08 </U>- Noise RT RR area. turning while going over uneven surface. see history. see Tim. 417099-00401. tighten all suspension bolts.
<U>6/14/08 </U>- Diag Suspens Concern. C/S knocking noise in right rear is more frequent than before. See Jeff. Metal from side still rubbing. separated metal and sprayed foam sealer in gap to prevent furhter rubbing.
I aint no engineer but should I accept a foam job on a car that cost $30K?
HELP!!
Old Aug 14, 2008 | 05:36 AM
Ross 2.0's Avatar
In a Junkyard near you.
Just about every seam that is not held together by a bolt or spot weld in your car is insulated either by foam or rubber resin.
Yes you should accept it.
Old Aug 14, 2008 | 05:41 AM
MSchu's Avatar
My Name is Nobody
Default Re: (Ross 2.0)
I want to know who diagnosed 12/13/07? seems like there is a lot of speculation in that narrative.
As all noise is coming from right rear and i assume this is a I4, check your exhaust system for movement and clearence
+1 on the expoxy seams as stated above
Here, you can clearly see the seamed epoxy on an 8th gen
Modified by MSchu at 12:44 PM 8/14/2008
TheMuffinMan
Sep 29, 2011 11:42 AM
clovet
Dec 14, 2006 06:57 PM
Oakmanx
Suspension & Brakes
Jun 20, 2006 07:16 AM
MonoDJ123
Sep 23, 2005 09:52 AM
