Electrical load detector how the hell do you fix this? PLEASE SOMEONE HELP
Old Aug 13, 2008 | 10:49 AM
tampabitches's Avatar
Default Electrical load detector how the hell do you fix this? PLEASE SOMEONE HELP
I JUST GOT A ECU FROM THE JUNK YARD THAT IS CHIPPED ITS A P28 AND I HAVE A 92 INTEGRA WITH A B16 WITH A CHIPPED P72 I SWITCHED THE ECU TO SEE IF THE P28 WORKED AND IT DID SO I SWITCHED IT BACK TO THE P72 AND AS SOON AS I DID THAT. I STARTED MY CAR AND DROVE DOWN THE STREET AND MY CAR STARTED JURKING SO I STOPPED AND CHECK THE CODE AND IT IS Electrical load detector SO I CHECKED ALL OF THE GROUNDS AND THEY WERE GOOD CAN SOMEONE PLASE HELP ME THANKS
Modified by tampabitches at 12:05 PM 8/13/2008
Old Aug 14, 2008 | 11:58 AM
nengx07's Avatar
Default Re: Electrical load detector how the hell do you fix this? PLEASE SOMEONE HELP (tampabitches)
SAME PROBLEM.. pls help HONDA-TECH PROS
Old Aug 14, 2008 | 06:25 PM
joevincett's Avatar
Default Re: Electrical load detector how the hell do you fix this? PLEASE SOMEONE HELP (nengx07)
I have the same problem in my 89 Sedan, if you search in the archived content everybody says to replace the under hood fuse box.
Old Aug 22, 2008 | 05:30 PM
nengx07's Avatar
Default Re: Electrical load detector how the hell do you fix this? PLEASE SOMEONE HELP (joevincett)
switch it with wat kind of fuse box??? i have a ek9 with b20 vtech swap.. any suggesstions??
Old Sep 21, 2008 | 06:52 PM
SinglecamMitch's Avatar
replace the fusebox with a ek9 one and its a vtec swap
Old Sep 21, 2008 | 06:55 PM
ltrkstr2k's Avatar
Default Re: (SinglecamMitch)
also make sure you dont have and open wires laying around.
egbaby
Nov 7, 2016 09:38 AM
kpjo4
May 30, 2009 07:24 PM
Guru Designs
Dec 29, 2005 01:11 AM
Guru Designs
Dec 28, 2005 09:33 PM
