replace fusebox???
replace fusebox???
so i have a chipped p28 and its throwing a code 20. Which is the ELD.( elctriacal load detector) The only way to fix it is replace the fuse box. Atleast thats what people say. Do i replace the fuse box inside the car or under the engine bay. Some people also said that i can just go to a place that can tune my ecu and ask them to disable the eld.
Re: replace fusebox??? (egbaby)
ELD is electronic load dectector. and yes, its located in your UNDER HOOD fuse box. it detects how much load your vehicle requires and compensates for voltage required to keep your vehicle in a proper state. search Honda-Tech for related ELD topics. if that doesn't help (which it probably will)... try and purchase a factory service manual. every possible problem can be solved with proper understanding and testing using the original manufacture service manual
89ED
05-11-2016 01:23 PM
AudioFunk
02-03-2014 08:09 AM
