obd1 in and obd2 how is it done
Old Aug 12, 2008 | 04:58 PM
williebrenn's Avatar
Default obd1 in and obd2 how is it done
ok i have a 96 civic dx hatch and i just got my hands on a 95 gsr full swap engine harness ecu and all now i also have a 97 gsr ecu laying around ... now i dnt have any kinda of engine harnes for the civic i dnt know were it got to wen i took the stock motor out so i was going to buy a 96-00 ex vtec harness is this smart wat else will i need to do wiring wise to put this 95 gsr in my 9 dx hatch please help asap help is much appreciated thanks guys....
Old Aug 12, 2008 | 05:21 PM
94EG8's Avatar
Seagull Management
Default Re: obd1 in and obd2 how is it done (williebrenn)
If your using a '97 GSR ecu, get a '96 - '98 EX harness, don't get a '99 - '00 harness, the ECU plugs are different. add wiring for the knock sensor. you'll need an OBD2 B-series alternator, injectors. Convert the OBD1 distributor to OBD2 either by using a conversion harness or change the plugs. wire the IABs, if you want them, this is optional. I probably missed something but thats at least most of it.
Old Aug 12, 2008 | 05:58 PM
Default Re: obd1 in and obd2 how is it done (94EG8)
can i use 310 cc ijectors from a 2000 si on this i plan to u se nitrious eventually and also there no wireing required for this no pin changes or anything???? Will all the civic plugs fit right on???
Modified by williebrenn at 11:13 PM 8/12/2008
Old Aug 13, 2008 | 05:02 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by williebrenn &raquo;</TD></TR><TR><TD CLASS="quote">can i use 310 cc ijectors from a 2000 si on this i plan to u se nitrious eventually and also there no wireing required for this no pin changes or anything???? Will all the civic plugs fit right on???
Modified by williebrenn at 11:13 PM 8/12/2008</TD></TR></TABLE>
Those injectors will work fine, no pin changes there, just the other stuff i mentioned earlier.
Old Aug 13, 2008 | 07:21 AM
iight im going to get All thise thing then post again on how to wire the knock sensor and anything else will i need to use the plug from the knock sensor??? On the integra harness??
Old Aug 13, 2008 | 08:27 AM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by williebrenn &raquo;</TD></TR><TR><TD CLASS="quote">iight im going to get All thise thing then post again on how to wire the knock sensor and anything else will i need to use the plug from the knock sensor??? On the integra harness??</TD></TR></TABLE> take the plug for the IAB (if you want to wire the IAB) and the plug for the knock sensor from the intergra harness.
Old Aug 13, 2008 | 03:44 PM
ok sounds good def will do do i wire the knock sensor in the spot d6 correct is it only a 1 wire plug or is there a power for it also????
50trimmed
Mar 7, 2011 09:12 PM
JSINS
May 1, 2007 07:18 PM
HB-Civic500
Oct 28, 2006 09:02 PM
dizzyek
Feb 7, 2006 02:58 PM
vshivik
Aug 28, 2002 12:29 PM
