Nippon 82mm p30 piston specs?
Old Aug 12, 2008 | 06:13 AM
BLACKLIST138's Avatar
Default Nippon 82mm p30 piston specs?
Man i got these off some twink on ebay and these ***** came with no spec sheet. If anyone has the info for me id be mondo appreciative. Ive looked in all the spots i can think of.
Thanks for any advice.
Old Aug 12, 2008 | 09:34 AM
damn too bad im not asking what color to paint my valvecover, someone may actually have some helpful suggestions.
Old Aug 12, 2008 | 09:56 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Nippon 82mm p30 piston specs? (BLACKLIST138)
You get what you pay for but I'll try to be helpful.
It's a typical cast piston with a p30 dome. What spec are you looking for? PTW, ring gap, CR....
Old Aug 12, 2008 | 10:09 AM
Default Re: Nippon 82mm p30 piston specs? (mar778c)
Yaaah. I think the clown just forgot to put the sheet back in there, but whatev. If i was building something nice it would not have cast pistons in it anyhow. this is just some junk, but id like it to run alright at least.
.0010-.0012 piston to wall ok?
this motor will probably see a 50 shot of spray sometime, so i may run it towards .0012
Piston mic'd out to 3.227 though...
far as the ring gap, im pretty sure the rings are pre gapped but any suggestions are appreciated.
thanks for the response brother...(p.s. Wong (B18c1 powered si) in your sig is a friend of mine)
Modified by BLACKLIST138 at 11:17 AM 8/12/2008
Modified by BLACKLIST138 at 11:18 AM 8/12/2008
Old Aug 12, 2008 | 10:17 AM
g2turbo's Avatar
I would like to know
-recommended piston/wall clearance
-recommended ring gap
-anyone that has used these wanna share their measurements?
Old Aug 12, 2008 | 10:22 AM
Default Re: Nippon 82mm p30 piston specs? (g2turbo)
This g2turbo guy is the cotton gin to this entire operation, so let either one of us know if you have any suggestions. thanks dudes
Modified by BLACKLIST138 at 11:32 AM 8/12/2008
Old Aug 12, 2008 | 10:47 AM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACKLIST138 &raquo;</TD></TR><TR><TD CLASS="quote">.0010-.0012 piston to wall ok?
.0012" is way too small, NA. 0.0032" is a more of what I would run with a shot of nitrous.
I wish Brian were still around. We need more members like him.
Old Aug 12, 2008 | 11:46 AM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">
.0012" is way too small, NA. 0.0032" is a more of what I would run with a shot of nitrous. </TD></TR></TABLE>
With cast pistons?
Old Aug 12, 2008 | 12:11 PM
4g hatch's Avatar
Default Re: Nippon 82mm p30 piston specs? (Combustion Contraption)
isnt .002 the max honda recomends on factory cast pistons? if its just a occasional small shot then i would think .001-.0015 would be fine.
marcel was probably thinking of forged pistons when he seen 82mm pistons
Old Aug 12, 2008 | 01:29 PM
DonF's Avatar
Default Re: Nippon 82mm p30 piston specs? (4g hatch)
Factory is 1 thing, Nitrous is another. That is why there is another forum for that crap. .0015 is a good number add some nitrous and I will give you a quote to rebuild it. Keeps my shop alive. But.but. but it was only a 50 shot. Why did my pistons melt?
Old Aug 12, 2008 | 01:34 PM
Default Re: Nippon 82mm p30 piston specs? (DonF)
Forget the nitrous garbage. just rebuilt with the pistons. what clearances do you suggest for piston to wall. .0012 is too small?
Modified by BLACKLIST138 at 2:40 PM 8/12/2008
Old Aug 12, 2008 | 01:50 PM
mar778c's Avatar
Community Builder
Sorry, I had doubled my number. It should be 0.0016" or like Don said.
No, 0.0012" is not too small.
Old Aug 13, 2008 | 04:42 AM
so do i tell my machinist to do it at .0012?
Old Aug 13, 2008 | 04:48 AM
mar778c's Avatar
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACKLIST138 &raquo;</TD></TR><TR><TD CLASS="quote">so do i tell my machinist to do it at .0012?</TD></TR></TABLE>
I would give myself .0004" to .0005" clearance because of nitrous.
I would ask for 0.0016".
Old Aug 13, 2008 | 07:00 AM
i decided against nitrous.
i have another car for that **** anyhow.
So .0012 it is.. Thanks for all your help dude.
Old Aug 13, 2008 | 07:03 AM
mar778c's Avatar
Community Builder
NP. Please post the results when you get it completed.
Old Aug 13, 2008 | 09:33 AM
g2turbo's Avatar
Thanks for the help
Old Aug 13, 2008 | 12:20 PM
i will post results once my stable hand g2turbo has assembled the engine and so forth.
thanks again
JDM97R
Jan 13, 2013 08:22 AM
nychonda
Apr 12, 2011 05:59 PM
TheoneTheycallVille
Oct 20, 2009 06:01 PM
ranta18
15
Jan 28, 2004 09:41 PM
PM-Performance
Jul 14, 2003 03:14 PM
