radiator fan decided it didnt want to turn on
Old Jul 22, 2002 | 08:59 PM
hybrider's Avatar
Default radiator fan decided it didnt want to turn on
got another one from the junk yard, and guess what? same problem
what else could be the culprit? the wiring? any how too's?
Old Jul 23, 2002 | 04:41 AM
kinesistech's Avatar
Default Re: radiator fan decided it didnt want to turn on (hybrider93)
The switch is on the thermostat housing. With key on, jumper the plug for it. Fan should come on. If not check the fuse and relay. If still no check your wiring.
Old Jul 23, 2002 | 08:21 AM
pfcfutrell's Avatar
Default Re: radiator fan decided it didnt want to turn on (kinesistech)
My friend's del slo had all kinds of cooling issues a short while back... the radiator cracked so we replaced it. Then it was still running hot so I checked and sure enough the fan wasn't coming on so I checked the fuses/relays and they were all fine (even jumped the fan to see that the motor worked). So I figure it must be the Coolant Temp. Sensor, now the fan would come on but it would still run hot, must be the thermostat. Replace the thermostat and fixes everything, I figue one thing broke and led to everything else breaking.
ATrin
Mar 17, 2008 07:24 PM
Donhonda84
Apr 4, 2007 08:36 PM
SpoonREVS
Jan 24, 2006 05:42 PM
EF8 JUNKIE9
15
Aug 27, 2005 08:35 PM
Finest
Jul 25, 2002 05:23 PM
