gsr swap, nothing coming from 1st cylinder
I just did a complete GSR swap, using the rywire harness, and using OBD2 Injectors cut the resistor box and spliced all the wires together.
Issue: Haven't wired up the toggle switch yet so I don't know what code is being thrown. I changed all the spark plugs and wires and I am getting spark on all cylinders, yet cylinder 1 is not getting anything. I removed the plug from cylinder 1 and nothing changed when the car was running. Does this sound like no fuel getting to the first cylinder? Or could this be TPS or Crank Angle Sensor issues.
Help a brrotthaaa out.
fire7882
17
Jul 13, 2002 07:29 PM
