mini me swap-vtec problems
Old Aug 11, 2008 | 05:33 PM
autowrench07's Avatar
Default mini me swap-vtec problems
hey im new to this place and i was wounderin if some one could give me some addvice i baught a 91 with a sohc zc swap so i converted it to obd1 and put a z6 head on it im throwin 2 codes i looked them up and one was from not havin a 4 wire 02 sensor and the other one was from a bad egr valve but im under the impresion that i dont have one since im throwin those codes my v tech wont work any ideas
Old Aug 11, 2008 | 05:36 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: mini me swap-vtec problems (autowrench07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autowrench07 &raquo;</TD></TR><TR><TD CLASS="quote">hey im new to this place and i was wounderin if some one could give me some addvice i baught a 91 with a sohc zc swap so i converted it to obd1 and put a z6 head on it im throwin 2 codes i looked them up and one was from not havin a 4 wire 02 sensor and the other one was from a bad egr valve but im under the impresion that i dont have one since im throwin those codes my v tech wont work any ideas</TD></TR></TABLE> Convert and or wire up a 4 wire 02.
inspect and possible replace EGR.
vtec will not engage with those codes running.
Old Aug 17, 2008 | 07:34 AM
Joseph Davis's Avatar
Default Re: mini me swap-vtec problems (***$nyper)
VTEC doesn't care about 4 wire O2 sensors, or EGR valves. Coolant temp, RPM, VSS, TPS, VTS, VTP, MAP is what the VTEC code looks for.
Sounds like the wrong ECU to me.
Old Aug 17, 2008 | 12:02 PM
Default Re: mini me swap-vtec problems (Joseph Davis)
i had the p28 in it and it was kickin a rev limiter in at 6000 so i switched it with my buddies and it took the limiter away but the v tec still didnt work so i have a p06 in it right now obveously vtec isnt there so would it be better to get a good p28 or should i get an rpm activated switch from jcwhitney and run it that way
Old Aug 17, 2008 | 06:05 PM
sit22 II's Avatar
did u remove the screw from the block?
Old Aug 17, 2008 | 07:51 PM
How about you back up a good bit and tell us more details about your car, and a timeline of what's been done recently + when exactly you started having problems.
Old Sep 12, 2008 | 10:17 AM
civic ef9's Avatar
im having kind of the wrong problem as well v-tec is not kicking in.did u solve wath was wrong with it?.
DAtegLs
23
Aug 4, 2008 10:58 AM
hondacivic90zc
May 13, 2007 01:12 PM
ALL-MoToR559
Feb 17, 2007 01:28 PM
Jdm_eF9boi
Apr 1, 2006 02:41 PM
c.dub
Jun 13, 2004 03:46 PM
