flywheel hotspots?
Old Aug 11, 2008 | 12:38 PM
ganjasnack's Avatar
Default flywheel hotspots?
hey i got this chromoly flywheel its f1 racing brand, i used it for a few months on my lsvtec and when i took it apart to put my new block on i see the flywhell has 3 hotspots on it. is the flywheel still good to use or is it junk now?
Old Aug 11, 2008 | 12:50 PM
ganjasnack's Avatar
Default Re: flywheel hotspots? (ganjasnack)
Old Aug 11, 2008 | 01:26 PM
non-VTEC's Avatar
that is the back side........what does the friction surface look like?
Old Aug 11, 2008 | 03:26 PM
greasemonkee's Avatar
If you can't have it resurfaced and get into fresh, unheated metal, I would think twice about reusing it. Once you get an alloy that hot it's properties change.
Old Aug 11, 2008 | 08:49 PM
projectTeG's Avatar
did you use a 3 puck clutch?
Old Aug 12, 2008 | 12:02 PM
ganjasnack's Avatar
Default Re: (projectTeG)
i used a 6 puck clutch and the contact surface has a slight dark tint to it on the other side of the 3 hot spots
Rocks
Aug 23, 2004 12:27 PM
redmethods
Mar 4, 2004 03:47 PM
tegon-gsr
Jun 30, 2003 08:49 AM
-=TWITCH=-
May 15, 2002 10:21 PM
