What is holding your shift boot up?
Old Aug 11, 2008 | 10:50 AM
jacksonww's Avatar
Default What is holding your shift boot up?
My shift boot is sagging - Is there a fix? What was used from the factory to hold it up? Viagra?
Old Aug 11, 2008 | 11:04 AM
1.8 HAMSTER EF's Avatar
zip tie haha
Old Aug 11, 2008 | 11:06 AM
JesseCRX's Avatar
Default Re: What is holding your shift boot up? (jacksonww)
I am one of those picky bastards that can't stand a saggy shift boot.
I have a B&M short shifter and it goes from thin to fat so it doesn't sag anymore.
Before I would get around 5 rubber bands and make a rubber ring around the shifter shaft. Then I would slide the boot/center console over it and the rubber bands would hold it up. This only works if your boot has that plastic ring at the top of the boot. I know some boots don't have it.
Old Aug 11, 2008 | 11:32 AM
monkeydude3602000's Avatar
i use a ziptie
Old Aug 11, 2008 | 11:33 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: What is holding your shift boot up? (JesseCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JesseCRX &raquo;</TD></TR><TR><TD CLASS="quote">I am one of those picky bastards that can't stand a saggy shift boot.
Before I would get around 5 rubber bands and make a rubber ring around the shifter shaft. Then I would slide the boot/center console over it and the rubber bands would hold it up. This only works if your boot has that plastic ring at the top of the boot. I know some boots don't have it.</TD></TR></TABLE>
Now I just need to find some rubber bands. Clever...
Old Aug 11, 2008 | 11:49 AM
fireant's Avatar
Default Re: What is holding your shift boot up? (phoenix_iii)
old injector cushions.
Old Aug 11, 2008 | 12:00 PM
EL Vap133's Avatar
Yup, rubber bands or zip ties and even tape in some cases will work.
Old Aug 11, 2008 | 01:12 PM
antbo's Avatar
Default Re: What is holding your shift boot up? (EL Vap133)
rubber bands and zip ties are the best invention ever made. especially zip ties. maybe theres a way to cuff the zip tie to hide it
Old Aug 11, 2008 | 01:27 PM
thesmogman's Avatar
Default Re: What is holding your shift boot up? (antbo)
I got one... Use a hair band/what ever you want to call it. Just keep looking for the right color. I sport a blue one!
From the factory they have a little plastic insert that fit's in there. Mine broke two days after I got my car. But it lasted 16 years.
Old Aug 12, 2008 | 07:23 AM
DAP91Si's Avatar
Go to Home Depot/Lowes to the plumbing section and get an o ring that will fit snug on the shift rod and hold up the boot.
Old Aug 12, 2008 | 07:41 AM
gibsanez's Avatar
Default Re: What is holding your shift boot up? (DAP91Si)
I have an 96+ civic boot and ****, they clip together
Old Aug 12, 2008 | 11:55 AM
spikehead221's Avatar
From: Staring down the barrell of my 12 ga. Texas, USA
Default Re: What is holding your shift boot up? (gibsanez)
ah
i dont have a boot, i want one.
used to be auto, but not anymore.
you could always rock no boot
Toe_Knee
Jun 26, 2008 02:25 PM
Gant
Apr 17, 2006 11:26 AM
jrmcafee
Mar 14, 2006 03:57 PM
-KangaRod-
May 15, 2004 07:12 AM
