how to disassemble the head on a b18c
Old Aug 11, 2008 | 10:31 AM
RIPPO's Avatar
Default how to disassemble the head on a b18c
im trying to take the head off my motor but im not exactly sure how to. i have taken off the cam shafts and now im not sure what else to do in or order for it to properly come off please help. thanks
Old Aug 11, 2008 | 02:42 PM
Dartanian's Avatar
Default Re: how to disassemble the head on a b18c (RIPPO)
You need to remove both manifolds, distributor, ps bracket, coolant hoses, and head bolts. It would probably be a good idea to pick up a service manual to assist with torque specs, tightening patterns, and disassembly procedures.
Old Aug 11, 2008 | 02:46 PM
ITR-EKcoupe's Avatar
is the motor out of the car?? if it is then its fairly simple, the head bolts are directly below the cams and cam caps down a half an inch or so. take the head bolts out 1/3 of a turn at a time in a criss cross patern. theres actually a proper patern to use, look around on the net youll find it
if its still in the car undo your exhaust mani an everything attached to your intake mani, or even jus undo the intake aswell. then do whats stated above.
Default Re: how to disassemble the head on a b18c (Dartanian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian &raquo;</TD></TR><TR><TD CLASS="quote">You need to remove both manifolds, distributor, ps bracket, coolant hoses, and head bolts. It would probably be a good idea to pick up a service manual to assist with torque specs, tightening patterns, and disassembly procedures.</TD></TR></TABLE>
ya beat me to it
Old Aug 13, 2008 | 06:05 PM
RIPPO's Avatar
the motor is still in the car. but thanks for all the help.
Accordian47
K Series
Aug 21, 2015 01:52 PM
brainglow
Dec 17, 2007 09:57 PM
EG civic
Sep 29, 2006 10:26 PM
Firestarter
Nov 5, 2005 01:30 PM
ITR #1202
Oct 1, 2003 09:23 AM
