need help type r #413
Old Aug 10, 2008 | 05:43 PM
gsrturboEK's Avatar
Default need help type r #413
need to know how high the compression in the motor should be i did a comp test and it read 160 across should it be that low? its a usdm ITR.
Old Aug 10, 2008 | 08:15 PM
JDM_320R's Avatar
Default Re: need help type r #413 (gsrturboEK)
that more seems for a b16.
b18c5 should be in the 210 - 235.
Old Aug 10, 2008 | 08:17 PM
Mr.OB*GYN_Rhett's Avatar
Really hard to tell by compression tests, fairly in accurate from my experience. Depends on how many cranks you let it go. Even across the board is a very good thing, so I would say you're good to go?
Old Aug 10, 2008 | 08:37 PM
gsrturboEK's Avatar
Default Re: need help type r #413 (Mr.OB*GYN_Rhett)
yeah 160 across but im thinking that its burning oil cause blows blue smoke and oil light comes sometimes. so thinking that i should rebuild also the motor been rebuilt before by A I thats what was stamped on head and block was wondering if anyone knows what the A I stands for or if anybody had there motor built by these guys
Old Aug 10, 2008 | 09:02 PM
Devon M's Avatar
A I = Artificial Intelligence.
Old Aug 11, 2008 | 01:59 AM
victorandolph's Avatar
blue smoke is fuel. maybe valves are loose or the piston rings are going bad. how many miles on it?
Old Aug 11, 2008 | 04:05 AM
01_ITR's Avatar
Default Re: (victorandolph)
135 in minimum for b18c5 engine....
I just did a compression test on mine and got 240 on all 4.
Make sure your doing the test right because it can throw off your readings. Unplug the fuel--i just disconnected the injectors and also you have to take out all 4 plugs, dont do one at a time and then put it back.
Compression test can only tell us so much, do a leak down test for accurate answers to your problems.
Old Aug 11, 2008 | 04:12 AM
tartje's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by victorandolph &raquo;</TD></TR><TR><TD CLASS="quote">blue smoke is fuel. maybe valves are loose or the piston rings are going bad. how many miles on it?</TD></TR></TABLE>
I know that you didn't mean to say fuel.
compression test numbers aren't worth counting on as it can vary from gauge to gauge, exactly the same as counting on dyno numbers
Old Aug 11, 2008 | 04:38 AM
Erik95LS's Avatar
Default Re: (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">Compression test numbers aren't worth counting on as it can vary from gauge to gauge, exactly the same as counting on dyno numbers</TD></TR></TABLE>
or redheads being fire crotches......
Old Aug 11, 2008 | 04:40 AM
tartje's Avatar
Default Re: (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">
or redheads being fire crotches......</TD></TR></TABLE>
exactly
Old Aug 11, 2008 | 04:48 AM
01_ITR's Avatar
what does this have to do with the guys problem..haha
Old Aug 11, 2008 | 05:22 AM
Erik95LS's Avatar
Default Re: (01_ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01_ITR &raquo;</TD></TR><TR><TD CLASS="quote">
what does this have to do with the guys problem..haha </TD></TR></TABLE>
it's an analogy further pointing out the effectiveness of relying on a comp test to prove motor healthiness.
Old Aug 11, 2008 | 02:37 PM
ithrowpoop's Avatar
not in my case.
Old Aug 13, 2008 | 08:27 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrturboEK &raquo;</TD></TR><TR><TD CLASS="quote">yeah 160 across but im thinking that its burning oil cause blows blue smoke and oil light comes sometimes. so thinking that i should rebuild also the motor been rebuilt before by A I thats what was stamped on head and block was wondering if anyone knows what the A I stands for or if anybody had there motor built by these guys </TD></TR></TABLE>
Wait... so you let the oil level get so low the light comes on?
Sounds like you at the very least need to check your oil more often... that's a big no no... lack of lubrication to the head is bad juju...
Old Aug 14, 2008 | 10:14 PM
gsrturboEK's Avatar
Default Re: need help type r #413 (Dave_B)
not that i just got the dang thing and it needs work....alot...
Old Aug 15, 2008 | 05:50 AM
LH-93's Avatar
Yea check that oil. Also that compression does seem low compared to what i have seen
Old Aug 15, 2008 | 05:53 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrturboEK &raquo;</TD></TR><TR><TD CLASS="quote">not that i just got the dang thing and it needs work....alot...</TD></TR></TABLE>
If the oil light is coming on, that's lack of oil pressure (Honda's idiot light) If your letting the oil level get low, this will happen.
Old Aug 15, 2008 | 08:43 AM
EARLdaSQUIRREL's Avatar
official honda whore
sounds like its in need of a rebuild, with the lack of oil and rather low compression numbers... how often is it consuming oil?
Old Aug 16, 2008 | 05:00 AM
ITR-965's Avatar
In order to include compression numbers in determining the health of the engine, you need to do a leak down test as well to check the state of your rings/lands etc... That will also determine why you are burning oil as well, which is causing your blue smoke concern.
Old Aug 16, 2008 | 05:41 AM
heel_touge's Avatar
Default Re: (ITR-965)
lets say i did a leak down and my numbers were awesome ( 2-3% in all 4). Yet Im losing/burning alot of oil.
would i first look to valve seals? i assume that because the valves are closed the leakdown is an inaccurate way to test them?
i alson notice a strong ol smell whenevr i come to stop (which would be negative manifold preassure right)
My PCV system may be shot. i pinched the line and couldnt hear the ball click but my motor is loud and im not sure exactly what im listening for?
Old Aug 16, 2008 | 09:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-965 &raquo;</TD></TR><TR><TD CLASS="quote">In order to include compression numbers in determining the health of the engine, you need to do a leak down test as well to check the state of your rings/lands etc... That will also determine why you are burning oil as well, which is causing your blue smoke concern.</TD></TR></TABLE>
the leak down is great, but with a cap full of oil and a compression tester i can tell you if its your rings or your valves....
do your compressoin check again and this time make sure you crank it over 8 times per cylinder and if they are still low add a half a cap full of oil to each cylinder, if the numbers skyrocket into the high 200s then its your rings
valve seals can only be diagnosed with a leakdown tester and if you replace on cylinders i would replace all of them at the same time to be safe
soedopelike89
Dec 9, 2010 09:16 PM
vipokc
Feb 4, 2009 06:57 AM
-HONDA-
12
Dec 19, 2006 10:43 PM
JJ's civic
13
May 2, 2006 08:57 PM
andystart
14
Oct 15, 2004 08:52 AM
