88 Si obd-1 DelSol USDM P30-A00 Ecu, wierd vtec problem?
Old Aug 10, 2008 | 10:22 AM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default 88 Si obd-1 DelSol USDM P30-A00 Ecu, wierd vtec problem?
Taken from this thread:
https://honda-tech.com/zerothread/2361668
Ok, I have a 88 CRX SI that has a 1st gen B16. I converted everything to OBD-1 to pass California BAR, which I passed. I have the S1 Cable transmission, with realy short gearing.(4200rpm 5th gear at 70mph) I have no CEL's, Runs strong.
Mods are AEM CAI, S2 IM, DC header, S2 Catback, and stock cat.
Well I went WOT on an open road for a 4th gear pull(2k rpm to 6k rpm) and vtec didn't kick in? It kicks in 1st-3rd, but didn't in 4th. Its a stock computer, USDM P30-A00, vtec at 5200. I have never tried 5th gear because I like my license.
I also have a P05 chipped with a Type-R basemap with bolt-on's, but heard its not good to run it on a engine its not made for.(To see if vtec kicks in at 4th gear)
Anyone with a DelSol vtec have this problem? I searched the archive and didn't find much. I don't understand why it works 1st-3rd but not 4th?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">electronic VSS in the trans, or feeding the ECU off the signal from the cluster?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc4iNtEgRa &raquo;</TD></TR><TR><TD CLASS="quote">VSS Signal is in the cluster, I didn't convert to VSS in transmission...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">oil pressure with RPM load? </TD></TR></TABLE>
What do you mean by that? Im sure the oil pressure is good because the light has never come on except before start-up. It doesn't burn, or leak oil at all, and its full.
Im thinking it has somthing to do with the TPS maybe? When the car is fully warmed up, the rpms bounce from 750 to 1250 for 10 seconds then idles at 700rpm. Also, when it does this, I can push on the pully for the butterfly on the TB and it stops bouncing. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc4iNtEgRa &raquo;</TD></TR><TR><TD CLASS="quote">Well I swapped out my ECU with the chipped P05 I have.(Disconected the battery, Removed the main fuse, Plugged it in, installed main fuse, connected the battery, let it idle for 20 minutes, then went for a drive.) Same thing, 1st-3rd Vtec at 5000, 4th nothing... Im confused, what else could it be? </TD></TR></TABLE>
[QUOTE=Relic1]I'm far from an EF guy, but I seem to recall something about the pulser unit in the cluster causing something like this. (signal gets muddy over a certain speed and the ECU sees the wrong signal)
It was fixable, fairly easy, but my lack of searching skills isn't turning up anything.
A post in the EF forum may help you get your problem solved. (if that's the problem)
Modified by Dc4iNtEgRa at 3:23 PM 8/10/2008
Old Aug 10, 2008 | 02:24 PM
Dc4iNtEgRa's Avatar
Default Re: 88 Si obd-1 DelSol USDM P30-A00 Ecu, wierd vtec problem? (Dc4iNtEgRa)
Old Aug 10, 2008 | 06:19 PM
Crx Jimmy's Avatar
I can think of 2a couple things to check off the top of my head. if you have an aftermarket distributor, like a distributor king, I have heard of them going wonky, try to borrow someones stock dizzy. ALso it could be a TPS problem check continuity and to make sure the voltages are reading properly. Also check the map, there could be a problem where it thinks the motor isnt under load so vtec doesnt engage. why it would happen only in 4th gear is a mystery
Old Aug 10, 2008 | 06:38 PM
Dc4iNtEgRa's Avatar
Default Re: 88 Si obd-1 DelSol USDM P30-A00 Ecu, wierd vtec problem? (Crx Jimmy)
I have a stock 95 GSR Dizzy... I haven't checked the TPS because I don't have a voltmeter... MAP sensor, IDK? Should be fine since I have had no CEL'S for 1000 miles... Im confused and need help... Thanks Alex
Old Aug 14, 2008 | 05:44 PM
Dc4iNtEgRa's Avatar
Does anyone know if a 97 Integra LS auto VSS will work in a S1 cable Transmission?
I have no CEL'S, and VTEC still doesn't work in 3rd-5th gears...
Old Aug 14, 2008 | 11:37 PM
Capo De Payne's Avatar
TIme for a new computer...
Old Aug 15, 2008 | 08:18 PM
Dc4iNtEgRa's Avatar
Default Re: 88 Si obd-1 DelSol USDM P30-A00 Ecu, wierd vtec problem? (Capo De Payne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Capo De Payne &raquo;</TD></TR><TR><TD CLASS="quote">TIme for a new computer...</TD></TR></TABLE>
ECU's are good, tested both in friends Delsol with B16, VTEC worked 1st-5th.
I tried my chipped P05, same thing, no VTEC in 3rd-5th...
I will test my TPS tomarrow, but if it wasn't getting the right voltage, then I would get a CEL right???
Old Aug 16, 2008 | 11:44 AM
Dc4iNtEgRa's Avatar
I know there are people on here with B16's that are converted to OBD-1...
TPS good, MAP good... Im lost
Old Aug 19, 2008 | 05:05 AM
Dc4iNtEgRa's Avatar
Anyone???
Old Aug 19, 2008 | 05:23 AM
crx_si-r's Avatar
v-tec solonoid??
Old Aug 26, 2008 | 05:33 PM
Dc4iNtEgRa's Avatar
Default Re: 88 Si obd-1 DelSol USDM P30-A00 Ecu, wierd vtec problem? (crx_si-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_si-r &raquo;</TD></TR><TR><TD CLASS="quote">v-tec solonoid??</TD></TR></TABLE>
Wouldn't it throw a code?
Lightsped
26
Jan 8, 2009 02:09 PM
Dc4iNtEgRa
10
Aug 19, 2008 05:07 AM
Dc4iNtEgRa
Aug 15, 2008 08:19 PM
TylerB
Apr 20, 2004 09:00 AM
