uk rear fog light
Old Aug 10, 2008 | 09:23 AM
hondadc2's Avatar
Default uk rear fog light
hello all
i need abit of help my rear fog light don't work i checked the bulb then looked under the bumper at the wires, connected to the foglight.The black wire has been cut some how its right near the foglight connected plug so i can't just cut the wire and connect to wires together, can anyone give me a clue what i can do or does anyone no where i can get a old rear fog from with the plug.
One more problem my passagers side door central locking is playing up it won't open and won't lock only buy key. I have took the door card off and sprayed wd40 no joy. Today i had a play with just unlocking the door with the key then locking it. Then i tryed my key fob to see if i done anything it worked only for about a min, what about if i get some wd40 and spary it in the lock of grease etc would that work manys thanks jay.
Old Aug 10, 2008 | 10:12 AM
Casey's Avatar
Default Re: uk rear fog light (hondadc2)
black wire is a ground. just connect it to something metal and the foglight should work fine. cant help you on the door lock sorry
Old Aug 10, 2008 | 11:04 AM
hondadc2's Avatar
Default Re: uk rear fog light (Casey)
hi thanks
just wondering if i can cut the to plugs off from the fog light and crimp the wires together so the black goes with the black and the blue and yellow goes with the black and red, if thats right.
Old Aug 10, 2008 | 11:14 AM
Casey's Avatar
should be. any solid black is ground, the other is power so you should be good to go
DCiFound
Lighting
Jul 13, 2014 07:57 PM
curtie94
Mar 18, 2011 07:07 PM
93_teg_CT
Mar 30, 2006 12:54 PM
civicmark
Audio / Security / Video
Jan 2, 2003 11:31 AM
integra-modder
Sep 23, 2002 09:17 AM
