hg leak of coolent help !!!!!!
Old Aug 9, 2008 | 08:08 PM
hiphop23j's Avatar
Default hg leak of coolent help !!!!!!
i just recently put my head back together on the gsr block, b16 head and gsr arp, i torque them down to 63 but i think they have to goten loose because im geting a litle leak where the gasket separates the head and block, please help is any thing messed up, i also have 1 dowl pin is that the problem
Old Aug 9, 2008 | 10:42 PM
vtecb18c's Avatar
Default Re: hg leak of coolent help !!!!!! (hiphop23j)
well you torqued them down to the specs but did you use ARP moly lube or just reg motor oil? if you used motor oil the head studs should be torqed again after 500 miles... someone might have another imput but i have seen a diffenence on using the moly lube than reg oil
Old Aug 10, 2008 | 03:14 PM
m00nr0ck Si's Avatar
Default Re: hg leak of coolent help !!!!!! (vtecb18c)
Did you check the block and head mating surfaces for straightness ? And why would you put the head back on missing one of the guide pins? The head studs will somewhat line it up correctly but the dowels hold it dead on....I would take it back off and get the dowels in and have the head surfaced and get another new headgasket....dont use a previously torqued one. just my opinion
1320vickers
Engine Machining & Assembly
Aug 3, 2018 12:30 PM
vaypourus
Oct 31, 2006 11:08 AM
2-logicl
Mar 27, 2006 07:04 PM
=ITRpoweredEK9=
Jan 23, 2006 12:25 PM
armrslr
Jun 23, 2003 11:45 PM
