Help removing roll pin from shifter rod
Old Aug 9, 2008 | 07:17 PM
luckii's Avatar
Default Help removing roll pin from shifter rod
I tried to buy a 8mm drift tool but could not find any at local shops. I also tried to use a 8mm bolt but the pin doesnt move and its hard to keep the bolt in one spot because of the threads. Is there any other way?
Old Aug 9, 2008 | 08:44 PM
slowcivic2k's Avatar
Default Re: Help removing roll pin from shifter rod (luckii)
A punch will work. Harbor Freight has some cold steel punches that are really cheap (literally) but they are strong enough to get the job done.
Actually, I haven't broken one of them yet.... And I do beat the hell out of them.
Old Aug 9, 2008 | 08:46 PM
luckii's Avatar
which size punch? i used one today and bent the **** outta it. lol. guess i gotta get a stronger one.
Old Aug 10, 2008 | 06:39 AM
stumpyf4's Avatar
5/16 or 8mm punch straight shaft punch. Use a mini sledge and give it a good wack.
I tried this technique but it's pretty fustrating. BFH and punch is the way to go!!
http://www.performanceforum.co....html
Old Aug 10, 2008 | 03:32 PM
1992Si's Avatar
B series or D series ?
D series I do from the top. Long 3/8 extension with a 7/32 hex on the 3/8 drive. 5lbs hammer. I think the tranny goes in 2nd gear, ?
Feed the long extension down by the throttle body with the 7/32 hex bit on it, on to the top of the bitch pin. I think you figure out the rest.
Old Aug 10, 2008 | 04:25 PM
BigMoose's Avatar
I machined an adapter for my air chisel out of stressproof steel rod to knock out the "b_tch pin" works like a charm!
Old Aug 10, 2008 | 05:41 PM
luckii's Avatar
its on a d series. i managed to finally get that bitch out but it took forever. i used a straight punch. i was wondering y it was so hard to take out until i saw that it was a spring. thanks for the advice.
Old Aug 10, 2008 | 05:42 PM
1992Si's Avatar
Default Re: (luckii)
It's get's easier. Let's hope you don't find that out.
Old Aug 10, 2008 | 06:24 PM
88ED8's Avatar
Default Re: (1992Si)
I just use one of those long bolts that come from the ac compressor, works perfect
flipldls
Mar 13, 2011 08:28 PM
krazym
Jan 6, 2008 09:45 AM
1993gsrcivic
28
Oct 5, 2007 11:43 AM
EJ1Dream
Jan 27, 2007 12:41 PM
USDM 4G VTEC
13
Nov 30, 2002 08:30 PM
