gauge lights and taillights don't work.
Old Aug 9, 2008 | 11:14 AM
L-Acura-S's Avatar
Default gauge lights and taillights don't work.
I am having a problem with my tailights, not the brake lights or turn lights jus the night lights that come one when you switch the headlights on. My gauge lights aren't working as well. I been looking around on the internet, and so far all I've come up with that could be the problem is the Headlights switch, and the fuses. I checked the fuses and they were still good but I changed them out any way. Has anyone here ever have this problem before, and it wasn't the headlight switch. Its a 98 integra ls.
Old Aug 9, 2008 | 11:32 AM
SkyliteCustomz's Avatar
i had the same problem before. It was the headlight switch crap, u know where the switch to turn on the headlights. My headlights would work but the gauge lights wouldn't. Changed it out and never had a problem since.
Old Aug 9, 2008 | 12:12 PM
L-Acura-S's Avatar
Default Re: (SkyliteCustomz)
so did you have to change out the wiring and the switch or just the switch or vise versa
Old Aug 9, 2008 | 12:16 PM
i only changed the switch.
Old Aug 9, 2008 | 01:11 PM
L-Acura-S's Avatar
aight well thanx for the info I appreciate it.
Old Aug 9, 2008 | 01:29 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: (L-Acura-S)
Same thing happened to me, but it was a fuse.
Old Aug 9, 2008 | 03:10 PM
dc2teg06's Avatar
Default Re: (PhantoM.DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantoM.DA &raquo;</TD></TR><TR><TD CLASS="quote">Same thing happened to me, but it was a fuse.</TD></TR></TABLE>
Same here, I had no tail lights, cluster lights, turn signal lights, fog lights, or climate control lighting. Check your fuses first, that is if you already haven't. Could be a simple fix
Otherwise check the wiring for shorts, and check to see if your grounds are sufficient.
Modified by dc2teg06 at 10:53 PM 8/23/2008
Old Aug 9, 2008 | 09:29 PM
L-Acura-S's Avatar
Like I said I checked the fuses.
Old Aug 15, 2008 | 08:18 PM
L-Acura-S's Avatar
So does anyone know of a problem that could cause this. Its not the fuses and its not the headlight switch. wiring right now is the last thing i need to check.
lilmarcEH3
Jan 28, 2010 04:29 PM
slowcivic e g
Nov 15, 2007 05:07 PM
jArceo
Feb 14, 2006 11:25 AM
