vtec not engaging.
Old Aug 9, 2008 | 09:11 AM
antivic's Avatar
Default vtec not engaging.
** IVE SEARCHED AND SEARCHED AND SEARCHED AND STILL SEARCHING **
my vtec does not engage for me what so ever...i have a 00 euro r h2b in a 93 hatch controlled by a p72 on hondata s200...i used this computer on reg h22 and it worked no prob.
my speedo works
my rpms work
i have plenty of oil
my coolant temp sens is working
my map sensor is working
vtec solenoid is new
i don't have a vtec pressure switch, but i did the bypass by connecting a wire from a4 to d6, the vtec press switch plug is grounded, and plug just hanging.
i was thinking it could be distributor related? everything runs smooth but vtec will not engage. i'm pretty sure i did the 8 wire to 9 wire conversion correctly because of the way it runs. but maybe i don't have the rpm signal lead in the right spot? any info would be great,
Old Aug 9, 2008 | 06:13 PM
antivic's Avatar
Default Re: vtec not engaging. (antivic)
anything? =/ still didnt get it
Old Aug 10, 2008 | 09:34 AM
antivic's Avatar
I changed with oil today just to see...and still nothing...im revving to 6800...it sounds like it changes over but hits rev limiter at 68...could it be distributor wiring? I've searched and found no answers...everything was left un answered...input please! thank u
Old Aug 10, 2008 | 03:12 PM
antivic's Avatar
OBD1 large plug............. goes to .................. OBD2 large plug
White/Blue ................................. REd
Orange/Blue ............................... Green
White .................................. Black
Orange .................................. Yellow
Blue/Yellow ............................... White
Blue/Green ............................... Blue
Yellow/Green .............................. Yellow/Green
OBD1 small plug .................. goes to ...................... OBD2 large plug
Black/Yellow LARGE ................................... Black yellow small
There is no tach wire on the OBD2 side....so the small blue on the second OBD1 distributor plug needs to get jumped....you can tee this into the yellow/green wire for a tach signal.
thats what i used for my distributor conversion, is it accurate?
Old Aug 10, 2008 | 06:33 PM
antivic's Avatar
ok so i found out vtec does hit, hits around 4800 and goes to 6800 and hits rev limiter, so i know its def not a vtec problem anymore...does it look like i did the distributor right?
Shane08
Apr 25, 2006 10:20 PM
TheIceMan
Dec 11, 2005 10:08 AM
Imprezor
10
Dec 1, 2005 03:37 PM
DsBananas94LS
Dec 5, 2004 07:51 PM
Doug684
Jun 12, 2004 07:20 PM
