Which Injectors for Turbo Setup????
Old Aug 9, 2008 | 07:05 AM
White94Civic's Avatar
Default Which Injectors for Turbo Setup????
I have a GSR in an EG hatch, and I'm looking to build a turbo setup for my car.....
This is my first time doing this, (my first Honda anyways) but I'm going to shoot for around 325whp or so. For now the stock long block will be used..... Hopefully that goal isn't too high of one.
But my question is, assuming my car makes around that power level I'm aiming for, which injectors would be recommended for something like that? I don't want to buy a set and then try to pull more power out of my combination later, and be limited to my injector size.
I'm using a P28 ECU if that makes any difference (OBD1). I also don't understand what a low impedance injector is either?
Thanks,
-Ant-
Old Aug 9, 2008 | 11:24 AM
GhostAccord's Avatar
Default Re: Which Injectors for Turbo Setup???? (White94Civic)
To be on the safe side a set of RC 750's will do you up to 400 Hp. It's always better to have more and run your injectors at a lower duty cycle. If you plan on going with more than 400hp then of course you'll need larger than 750's to stay on the safe side.
Old Aug 9, 2008 | 05:14 PM
So where is a good place where I can a reasonable price for a set of these injectors???
Old Aug 11, 2008 | 03:21 AM
Default Re: (White94Civic)
Not sure exactly. I got my DSMs off ebay for a good price. You might want to try there or take a peak in one of the market place forums here on H-T.
Old Aug 11, 2008 | 04:44 PM
432boosted's Avatar
Default Re: Which Injectors for Turbo Setup???? (GhostAccord)
I GOT A QUESTION I GOT 1000 CC INJECTOR ON MY TURBO INTEGRA IS THAT WAY TOO MUCH AND WHAT COULD I BUY TO CONTROL THE DUTY CYCLE ON THE INJECTORS
Old Aug 11, 2008 | 05:49 PM
HandlelyThePanda's Avatar
Default Re: Which Injectors for Turbo Setup???? (432boosted)
It depends on how much psi you plan on running. And please turn CAPS off.
Old Aug 11, 2008 | 06:43 PM
432boosted's Avatar
Default Re: Which Injectors for Turbo Setup???? (HandlelyThePanda)
im running ten pounds of boost
Old Aug 12, 2008 | 04:08 PM
Some DSM 440's should be fine.
Here's duty cycle info for you.
http://www.stealth316.com/2-calc-idc.htm
Old Aug 13, 2008 | 06:22 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 432boosted &raquo;</TD></TR><TR><TD CLASS="quote">im running ten pounds of boost</TD></TR></TABLE>
ten pounds means nothing.
10psi on a T25? Or a GT42?
The market place usually has good deals.
pugdug808
Oct 31, 2016 04:34 PM
bigtom388
Oct 16, 2008 04:33 PM
Tyte-S
Oct 13, 2007 08:32 PM
firstclassjdm
Feb 28, 2005 03:03 PM
DriveSlowHomie
Feb 18, 2005 11:59 AM
