Burning oil after rebuild
I got my head rebuilt on my GSR (swapped into CRX) and put it on a block that i had purchased off of a guy on HT. The cylinder walls looked great, so i don't suspect leaking rings, but i'm definitely blowing smoke. Car has sat for about a year and i just put in a new fuel tank and pump assembly. It seems to run OK, just blowing smoke. I haven't had it running long enough to know what "normal" would be for engine sound/what to expect. What could the possibilities be? I'm not sure of the mileage on the block.
yeah that's what im thinking, the pan was oil tapped for turbo and i didn't realize it when i picked it up. I wish i had the guys number but there's nothing i can do now, a year+ later. I'll see about getting my hands on a compression tester.
Start with a compression check, if all cylinders have good numbers and less than 3% difference then look into a leakdown test. You can tell a lot from just these two tests and they are simple to do.
If they both check out ok then you may want to check valve seals.
i finally got a chance to pick up a compression tester and test it. The compression looks within spec on all cylinders, 3 is a bit low, but not at the "bottom level" that's within the specs. I'm still burning oil like a MF, a blue ploom out the exhaust, and my plugs are all black when i take em out. Aren't valve seals normally replaced with a rebuild?
Modified by rtnlsltn at 10:21 AM 8/23/2008
reupping this, it didnt previously burn oil this bad, it was previously burning lots of gas (reason why i changed the fuel pump) so im trying to figure out where it's all getting in and why. I just checked inside the IM and noticed theres some oil sitting in there, not a lot, but enough to make e few small puddles. Anyone have any ideas? I'd rather not take it apart and rebuild if i don't have to
Modified by rtnlsltn at 9:14 AM 9/13/2008
measure piston to wall clearance and see if it's even possible to re-ring. some worn out thrashed on motors will get the piston to wall up to .008 or .009, reringing is a waste of money if there is that much wear on the pistons and walls...ususally pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayare05 »</TD></TR><TR><TD CLASS="quote">valve seals are toast.. thats what blue smoke usually indicates.</TD></TR></TABLE>
I'm not disagreeing with you that it could be the valve seals, but blue smoke means that you are burning oil. It doesn' tell you where it's coming from.
