Rear brake conversion help
hey guys, i recentlly put rear disc brakes on my 95 EJ1 from a 94 del sol, everything fit like a glove, im only having one concern, i feel that the pedal is to low, its not spongy and it maintains pressure but its real low. i blead the intire system untill there was no bubles coming out and new fluid came out each line, i also regulated the parking brake so it would engage at around 5 clicks, but its still low. i dont know what else to check or adjust. any advise would be really helpful. the pedal feels like when drum brakes are out of adjustment. thanks
u can adjust the brake pedal, connected to the pedal there is a metal rod with a pin holding it in place, remove pin and remove rod. then turn the rod coming from the brake mc clock wise.. but i would recommend buying a brake bleeder available at harbor fright or something and bleeding ur brake system.. afew more times.
http://www.harborfreight.com/c...92474
Fishyboi4
Feb 1, 2011 09:45 AM
ricehater60453
Honda Civic (2001 - 2005)
Jul 12, 2010 11:25 AM
hermtm2
May 8, 2009 10:33 AM
