new head and gasket still white smoke?
Old Aug 7, 2008 | 05:34 PM
missionaryrider's Avatar
Default new head and gasket still white smoke?
hey, i have a b15b and i put a 96 1.6 head onto it that was rebuilt at a shop.
still is blowing smoke like a train i dont understand???
Old Aug 7, 2008 | 06:15 PM
G2_Fella's Avatar
Default Re: new head and gasket still white smoke? (missionaryrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by missionaryrider &raquo;</TD></TR><TR><TD CLASS="quote">hey, i have a b15b and i put a 96 1.6 head onto it that was rebuilt at a shop.
still is blowing smoke like a train i dont understand??? </TD></TR></TABLE>
did you take the head to a machine shop?
Old Aug 7, 2008 | 06:23 PM
SOHC SPEED's Avatar
sound like you might have a some bad piston oil rings
Old Aug 7, 2008 | 07:40 PM
Default Re: new head and gasket still white smoke? (G2_Fella)
Yeah they completly rebuilt the whole thing presure tested it , the whole deal. IM assuming its the rings just wondering itf it might be anything else.
Old Aug 7, 2008 | 08:40 PM
blkegcoupe's Avatar
From: ....................................................................................................
is it still white smoke?
SOHC SPEED's Avatar
if it was doing the same thing before you had the head checked, chances are its the rings
Old Aug 8, 2008 | 10:21 AM
94EG8's Avatar
Seagull Management
You say the smoke is still white, correct? that would be coolant, bad rings will not cause you to burn coolant, they will cause you to burn oil, which smokes blue. I'd say either the head gasket didn't seal either because the head and block mating surfaces weren't cleaned well enough, damaged from being cleaned with abrasives, head wasn't torqued properly or the block deck surface is warped. Again to reiterate what i've said in countless other threads, do not waste your time trying to put head gaskets in engines that have overheated, you will more often than not have problems.
kidd3121
Feb 18, 2008 01:20 PM
eg6civic1538
Apr 22, 2007 06:36 PM
Daniel_san
30
Apr 24, 2004 09:42 AM
cecilseahawks
Nov 7, 2003 08:19 PM
petrv
Jul 11, 2003 11:53 AM
