eg is blowin white smoke??
Re: eg is blowin white smoke?? (eg6civic1538)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6civic1538 »</TD></TR><TR><TD CLASS="quote">IM BLOWING WHITE SMOKE COULD IT BE THE VALVES OR VALVE SEALS??? HOW CAN I TELL??</TD></TR></TABLE>
White Smoke = Coolant.
Which in turn would most likely be a blown headgasket.
i have the same problem but i have ls/vtec changed head gasket and coolant and pretty much every seal and oil is leaking a little n can be felt when you wipe your finger under the valve cover could i need need different head studs thats what my friend keeps saying
Re: (heeltoeNdro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by heeltoeNdro »</TD></TR><TR><TD CLASS="quote">i have the same problem but i have ls/vtec changed head gasket and coolant and pretty much every seal and oil is leaking a little n can be felt when you wipe your finger under the valve cover could i need need different head studs thats what my friend keeps saying</TD></TR></TABLE>
When you type something...use punctuation.
I have no idea where you begin and end.
Re: (deadline)
its been awhile most likely.. i have loss in power too so maybe ill try the head gasket first...could i use a 96-00 head gasket?? i think they are thinner, and why not raise a little compression while im in there...lol
Re: (eg6civic1538)
trust me on this, white smoke DOES mean coolant, but if you have never seen either coolant smoke or oil smoke, both can be interpreted as "white" therefore, he may be burning oil...
do you smell a sweet-ish smell? if so its coolant, and im ready to bet you need a new headgasket
its hard for me to describe burning oil to you so check your rear bumper for thick black dust, if so, you are probably burning oil and it could be a number of things to leaky valves, to rings, to headgasket aswell, we need more info, really
Clash0901
12
06-06-2010 01:36 PM
BoOsTiN Dc2
07-03-2004 08:19 AM
