what mods to head for turbo or FI
Old Jul 22, 2002 | 02:34 PM
rOby's Avatar
Default what mods to head for turbo or FI
what kinda mods should i do to my gsr head for high boost or nos as far as modifications... retainers , ferrea valves...what should i get and whats the best places to get these parts thanks. the bottom end is built btw.
Old Jul 22, 2002 | 09:52 PM
ion_four's Avatar
Default Re: what mods to head for turbo or FI (roby)
nothing
Old Jul 22, 2002 | 09:56 PM
VaporTrail's Avatar
New User
how much power are you looking to make?
Old Jul 22, 2002 | 10:00 PM
rOby's Avatar
Default Re: what mods to head for turbo or FI (VaporTrail)
when its turbo atleast 300whp and near 400 on race gas. after it gets outta shop ill probably just spray 125 until funds come back up for turbo...
Old Jul 22, 2002 | 10:21 PM
VaporTrail's Avatar
New User
I'd stick with ITR springs and maybe a set of titanium retainers. The step up from that would be Portflow inners, and from there - I'd jump to the full Ferrera valve train.
Old Jul 22, 2002 | 10:25 PM
Arturbo's Avatar
Better than steak
25 Year Member
What mods? Maybe Arturo, teken,gsrgrrl, dustin or MarkC. Jk, that was a lame joke.
Well If you are gonna boost it you can get away with it stock. Save the money and do an entire rebuild later down the road.
art
Old Jul 22, 2002 | 10:27 PM
rOby's Avatar
which itr springs..inner or outer, intake or exhaust. how much would such head work cost? like a ferrera valve train for example.? thanks for ur help vapor
Old Jul 22, 2002 | 11:28 PM
accordfreak's Avatar
when is it necessary to upgrade the head? is it if you want to go past redline? or a cetain number of hp? i pretty much learned a lot about the bottom end on this board but not much on the top end..
Old Jul 22, 2002 | 11:45 PM
VaporTrail's Avatar
New User
if you're going to rev beyond stock, I'd definately upgrade the exhaust springs to ITR spec inner and outer. Stock GSR/B16 only has a single spring exhaust side. I'd look at upgrading the valves only if you do head work along with it.
Old Jul 23, 2002 | 12:03 AM
so if i always shift at red line when i race and don't go beyond that then I will be fine right?
thanks for your help.
Old Jul 23, 2002 | 12:11 AM
VaporTrail's Avatar
New User
Default Re: what mods to head for turbo or FI (accordfreak)
sounds about right, unless the oem valve train is inherently weak
Old Jul 23, 2002 | 03:30 AM
ninesecrx's Avatar
I fit were me...id do a set of crower or webb cam springs and retainers. One thing you have to remember is just because you have a revlimiter, does not mean it stops a motor from over reving. There is still inertia envolved on aceleration. The revlimiter cuts the ignition and doesnt let it revpast that number but it does nothing to stop your motor from reving higher. Also...the boost is going to push against your valves and looking the kind of power you are...i will bet you will have trouble with 400whp...with out doing the complete kit. If you drop a retainer, you can kiss your motor good bye. I think you should do it right the first time because these are parts that should last you even if you did an all out race motor down the line....Mike
Old Jul 23, 2002 | 04:22 AM
rOby's Avatar
Default Re: what mods to head for turbo or FI (ninesecrx)
what kinda prices could i look forward to on a head buildup..springs retainers and im assuming valves?
Old Jul 24, 2002 | 01:14 AM
ninesecrx's Avatar
500-800 bucks...
Old Sep 17, 2002 | 07:41 PM
would 500-800 dollars cover everything that's needed to rev a little past redline? what would be included? springs.. retainers ?
btw my red line is about 6200... i want to rev probably as high as 8k or so.. safely of course..
just to learn about the engine head... what kind of parts consist of it?
[Modified by accordfreak, 4:42 AM 9/18/2002]
Old Sep 17, 2002 | 08:23 PM
oh yeah... if i go 2mm over on the sleeved block then i would have the increase the the head combustion chamber 2mm over also correct? do i have to go with bigger valves?
would the idle change if the head is modified?
[Modified by accordfreak, 5:23 AM 9/18/2002]
4CDFED
Jul 7, 2006 08:02 PM
Serdar
Apr 25, 2005 02:12 PM
dc2monkie
Sep 24, 2003 04:31 PM
01ITR#700
Feb 21, 2003 11:15 PM
