370 injectors
I have the chance to get a set of RC 370 injestors for 220. They have only been used for like 20 miles. I have a ZC and maybe turboing it. I want to run them without turbo thoe. Will this be to much fuel or can I do it.
Thanks
Thanks
Guest
Posts: n/a
buy 1st gen dsm jectors (440-450 cc) for $40 a set. rcs dont actually flow at the rate they're rated for. they flow less. you will have to fun a fuel management systems to handle em etc
[Modified by TorteX, 4:19 PM 7/22/2002]
Guest
Posts: n/a
http://www.thepartstrader.com
i believe you have to enlarge the grommet for the fuel rail. not a big deal, lil rubber deal, drill it out
Thanks
Thanks
buy the DSM 450's, but you really can't use them for all-motor... If you can find a 5-speed DOHC NON-Turbo DSM they have 370cc injectors, that go in just like the bigger 450s.. I put the 450ccs in my D15B2 ( with MPFI and an SI head ) and with a VAFC AND an adjustable FPR I couldn't get it to run well... They are great on turbos though ( I hear ), that's what I;m going to use them for...
El Veterano de Sur Califas
89dxhunchback....well i have a couple questions for you. Can u give us some more details in what settings u used, and what exactly did u try. example: what percentage did u take a way from the injectors on the vafc? What fuel pressure did u have it at? what kind of fpr do u have? because if u have a b&m, you can only go higher that stock, not lower....from what i have heard. Since it uses the stock diaphram. I am very intrested , becasue i have been trying to find people who have actually tried this. I will be trying this out after i get a few good testimonies. I have a b18c1, so i might have better luck
and to the original poster...if you have a fuel controler(vafc,safc,fields) then yea, u might as well try it. And just stick around this and my other post i have. And do aolt of research!!
manny
manny
CivicRaping
Apr 12, 2005 12:05 AM
