Need help in buying coilovers for my EK!!!
Old Aug 6, 2008 | 08:06 PM
FRKWOO's Avatar
Default Need help in buying coilovers for my EK!!!
i want to buy some new adjustable coilovers for my ek but i have a budget and dont have much. whats the best adjustable coilovers i can get for like 600-700 get get the best for my price limit? please post links where i can buy from thanks in advance!!
Old Aug 6, 2008 | 08:28 PM
luder916's Avatar
For that I would recommend tokico illumina's with ground control. Check Ebay and make sure that the ground controls are for the illumina's.
Old Aug 6, 2008 | 08:37 PM
bmoua's Avatar
skunk2 slip over coilovers w/ illuminas or ground control coilovers w/ illuminas.
Sk2's setup will be a bit stiff but perfect for a DD with intentions of spirited driving. The ground controls is perfect if your looking just for a nice drop with a oem quality like ride.
Old Aug 6, 2008 | 08:41 PM
FRKWOO's Avatar
Default Re: (bmoua)
^^^^how much and where can you buy them at thanks guys!!!
Old Aug 6, 2008 | 08:48 PM
bmoua's Avatar
Default Re: (FRKWOO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRKWOO &raquo;</TD></TR><TR><TD CLASS="quote">^^^^how much and where can you buy them at thanks guys!!!</TD></TR></TABLE>
look in the sponsers thread...
i would buy the coilovers used and buy the shocks new, saves you a little $$$. Both sets of coilovers should run anywhere from $80-$200 used. I found my Sk2 coilovers for $120 used. As for the illuminas your looking at $380-$430 depending on which shop you buy it from. You can also consider the kyb agx's or skunk2 sport shocks. I'd def. recommend the skunk2 sport shocks paired with the skunk2 coilovers if your looking to spend as little as possible while still maintaining quality parts.
research about spring rates, the higer the spring rates the worst ride quality gets.
Old Aug 6, 2008 | 10:48 PM
FRKWOO's Avatar
Default Re: (bmoua)
would theod and are they adjustable?? ^^^thanks for all the help dudde!!
http://jhpusa.com/store/pc/vie...t=358
Old Aug 8, 2008 | 04:42 PM
FRKWOO's Avatar
would these be a good deal on adjustable coilovers??
or these
http://jhpusa.com/store/pc/vie...=3836
Modified by FRKWOO at 5:57 PM 8/8/2008
Old Aug 8, 2008 | 07:21 PM
thegoudster's Avatar
the sponsor section has ground controls with koni yellows for $789 or so shipped. IMO it'd be worth the extra little bit.
Old Aug 8, 2008 | 10:19 PM
illmatic118's Avatar
these are the ones that im gonna buy for my ek there pretty good only 835$ http://picperformance.com/stor...t=193
Old Aug 8, 2008 | 10:21 PM
JDM_320R's Avatar
Default Re: (thegoudster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegoudster &raquo;</TD></TR><TR><TD CLASS="quote">the sponsor section has ground controls with koni yellows for $789 or so shipped. IMO it'd be worth the extra little bit.</TD></TR></TABLE>
koni FTMFW
Old Aug 8, 2008 | 10:59 PM
FRKWOO's Avatar
Default Re: (JDM_320R)
why are these konis so cheap 282 plus shipping??
http://www.koni-na.com/cat_sea...earch
but right now im really jus leaning on gettin the skunk2 pro c
Modified by FRKWOO at 1:57 AM 8/9/2008
Old Aug 9, 2008 | 03:22 AM
Davus's Avatar
288 per pair, you'll need two pairs unfortunately. :-)
Old Aug 11, 2008 | 12:46 PM
Default Re: (illmatic118)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illmatic118 &raquo;</TD></TR><TR><TD CLASS="quote">these are the ones that im gonna buy for my ek there pretty good only 835$ http://picperformance.com/stor...t=193</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "PIC" &raquo;</TD></TR><TR><TD CLASS="quote"><u>Fixed damping</u> height adjustable coilovers. Ideal upgrade for those that require not only height adjustability, but track-oriented performance gains.</TD></TR></TABLE>
Just so you know those are only height adjustable. The dampers are not adjustable. With the Koni/GC combination it's cheaper and you can fully adjust height and dampening.
Old Aug 11, 2008 | 03:36 PM
robfrmny21's Avatar
d2,ksport,pics your choice
Masho2013
16
Apr 21, 2013 06:22 AM
eg6sittingon57cs
Dec 16, 2009 09:13 PM
lj420p
Suspension & Brakes
Feb 2, 2005 07:47 AM
HatchbackSiVtec
20
Mar 18, 2003 09:09 PM
bocian
Mar 13, 2002 08:27 AM
