Transmission Question For The Major Built Engines.
im currently building my engine for about 500whp on a b18c1 engine, and i was wondering what the people with high hp were doing for trannys..will they hold stock (i know aftermarket clutch is needed) but im talking about the gearing and lsd itself.
thanks in advance
thanks in advance
With that low hp # a stock tranny will hold up fine. It's the torque # you need to worry about. Again, with the low # you'll be making you'll be fine.
You may want to look into better axles.
Check out the drag racing forum. The guy's with the 700+whp are still using OEM gear sets.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si »</TD></TR><TR><TD CLASS="quote">With that low hp # a stock tranny will hold up fine. It's the torque # you need to worry about. Again, with the low # you'll be making you'll be fine.
Check out the drag racing forum. The guy's with the 700+whp are still using OEM gear sets.</TD></TR></TABLE>
this is awesome to know...the tuner car i just came from was 75% maxed from the factory for power holding...thanks alot for the help
drtalon123
Transmission & Drivetrain
Nov 12, 2010 02:30 PM
