put a new to me head on my car
Old Aug 5, 2008 | 03:52 PM
steveharrmr23's Avatar
Default put a new to me head on my car
put a new had on my car and adjusted the valves now and it still smokes bad when i idle and i stomp the throttle if i am in first gear and i try to take off quick it bogs to all most stall out is it normal for them to smoke for a lil bit at first cause i just put it together there is not even 30 miles on the new gaskets
Old Aug 5, 2008 | 09:35 PM
lmike6453's Avatar
If it smokes around the head itself you may want to fix your cam tming so the pistons aren't hitting the valves.
If it's smoking from the rear exhaust then you should see if your coolant is mixing with your oil.
Old Aug 6, 2008 | 03:25 AM
turbodcxbro's Avatar
Default Re: (lmike6453)
Sounds to me like you either screwed up the install or the head has bad valve seals/guides.
Old Aug 6, 2008 | 06:19 AM
neardon's Avatar
I'm a Jackass
Default Re: put a new to me head on my car (steveharrmr23)
You changed the head because it smoked? You didn't do a compression check or look into the piston rings? You might be due for a new block too.
Old Aug 6, 2008 | 06:44 AM
ruffrhyder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 &raquo;</TD></TR><TR><TD CLASS="quote">If it smokes around the head itself you may want to fix your cam tming so the pistons aren't hitting the valves.
If valve to piston contact already occured what good will adjusting the cams do? Assuming the OP even has adjustable cam gears.
Old Aug 6, 2008 | 08:18 AM
Default Re: (ruffrhyder)
i think i figured it out when i put a new head on my car i also installed a new oil pressure gauge and it came with a plastic oil line and that line blew off i think it did some damage cause there was not a problem until that happen
Old Aug 6, 2008 | 08:28 AM
Honda Tool's Avatar
2010 Honda-Tech Poker champion
If it's smoking from the rear exhaust then you should see if your coolant is mixing with your oil.</TD></TR></TABLE>
lol
Old Aug 6, 2008 | 08:41 AM
lmike6453's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruffrhyder &raquo;</TD></TR><TR><TD CLASS="quote">
This was what happened when i didn't set the timing right the first time I did a t-belt install. The timing was off more than slightly...
http://www.youtube.com/watch?v=kxHvN16Y3Bc
After fixing the timing without letting the engine run more than the time in the video, everything was fine and compression is still in spec.
Old Aug 6, 2008 | 08:46 AM
ruffrhyder's Avatar
After fixing the timing without letting the engine run more than the time in the video, everything was fine and compression is still in spec.</TD></TR></TABLE>
Improper belt installation and valve to piston contact are 2 totally different problem. Sure one can lead to the other, but like I said earlier, if valve to piston contact already occured, what good will adjusting timing do?
mf1990
Jun 17, 2009 09:11 PM
R.Kelley
Apr 5, 2008 11:11 PM
charlie_sohc
Dec 14, 2007 12:37 PM
1.8
Feb 12, 2005 11:33 AM
drevinder
Feb 10, 2004 02:33 AM
