need help with check engine light 90 crx si with gsr swap
Old Aug 4, 2008 | 09:40 PM
hetas87's Avatar
Default need help with check engine light 90 crx si with gsr swap
hey guys I just finished swaping in a b18c1 into my 90 crx si.
It has a p28 ecu with obd 1 jumper I put the toggle swith for the check engine light and grounded it and the light dont blink or anything dont I have to ground it too to check the ignition timing
Old Aug 4, 2008 | 09:50 PM
Maxcapacity's Avatar
Default Re: need help with check engine light 90 crx si with gsr swap (hetas87)
under the passenger side dash theres that 2 wire clip to jump together for the timing, use a cotter pin to bridge them together. your check engine light should flash now to show codes by doing the same step for the timing.
Just make sure you turn the key to first position to check codes... if you no that already!
Chavy340
Oct 14, 2011 05:17 PM
fAyJai510
Aug 6, 2011 12:03 AM
924drcivic
20
May 31, 2009 12:05 PM
egLs20
Sep 21, 2004 04:26 AM
obsessed247
May 22, 2002 02:57 AM
