How much oil does a tranny hold
How much does a tranny hold. I have about 1.5 quarts if synthetic motor oil in it. I was told the tranny can hold almost another quart.
Its a 91 acura interga tranny on my b16..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIGPA26 »</TD></TR><TR><TD CLASS="quote">How much does a tranny hold. I have about 1.5 quarts if synthetic motor oil in it. I was told the tranny can hold almost another quart.
Its a 91 acura interga tranny on my b16..</TD></TR></TABLE>B-series transmission - 2.4 quarts for rebuild - 2.3 quarts for oil change
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIGPA26 »</TD></TR><TR><TD CLASS="quote"> I have about 1.5 quarts if synthetic motor oil in it.</TD></TR></TABLE>
i would not suggest synthetic motor oil. use honda MTF. its got the right additives for a transmission an engine oil wouldnt have. and sythetic actually doesnt work well with sycnhros, from what i heard.
either way, just use honda MTF.
i was told to use synthetic motor oil. I have about 1.5 quarts in there and need to add a quart sometime my 5th gear gives me problems and thought of that
Why instead of guessing do you not just go buy a bit more than needed, pull the overfull bolt out and top it up to exactly where it should be instead?
Go buy 1 qt of penzoil synchromesh 2 gt of regular 10w30 and put all the synchromesh in, then add 1qt of oil, then add half of the other oil.
Now you be shifting with the butterness.
doublejz
14
Sep 27, 2005 04:24 PM
