removing exterior window trims
is there a topic on this already?? if so, can someone lead me the direction? thanks!
i need to know how to take out the outer piece, that 1 piece trim/moulding that go around the door at the top and the piece at the bottom of the windows. correctly and safely. thanks!!
Look on each end for a phillips head screw and then lower the glass, lift but angle it towards the interior of the car and each clip should release with even pressure
^^thanks!! got that covered, but now hope someone else chimes in for the 1 piece that wraps around both doors.
B16_4ME
May 26, 2009 06:47 AM
