d16a6-T or b18a?
Old Aug 4, 2008 | 06:30 AM
redef90si's Avatar
Default d16a6-T or b18a?
i'm in the process of deciding if i should get my a6 block rebuilt and go turbo down the road or buy in the b18.I have driven a ef with a b18 and enjoyed it a lot but was wondering how it pulls compared to a lightly modded turbo a6?I will be just replacing stock internals and would just use the stock spring on the turbo(5,7,or 10 psi)I'd be runnig a t3/4 turbo for those of you out there that are goin to bring the size of the turbo into discussion; just looking for your guys input,Thx.
Old Aug 4, 2008 | 07:20 AM
JustAnotherRex's Avatar
Default Re: d16a6-T or b18a? (redef90si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redef90si &raquo;</TD></TR><TR><TD CLASS="quote">i'm in the process of deciding if i should get my a6 block rebuilt and go turbo down the road or buy in the b18.I have driven a ef with a b18 and enjoyed it a lot but was wondering how it pulls compared to a lightly modded turbo a6?I will be just replacing stock internals and would just use the stock spring on the turbo(5,7,or 10 psi)I'd be runnig a t3/4 turbo for those of you out there that are goin to bring the size of the turbo into discussion; just looking for your guys input,Thx. </TD></TR></TABLE>
B18 is going to have more long term potential if you wanted to turbo that down the line, although it will be a squeeze.
The A6 turbo'd could walk the B18 though.
Old Aug 4, 2008 | 08:38 AM
redef90si's Avatar
Default Re: d16a6-T or b18a? (JustAnotherRex)
I think i'll rebuild the bottem end and then drive that for a bit and then decide if i wanna go turbo or b series.I'm leaning more towards turbo for a few reasons;I have a buddy who can tune it for relativlly cheap,no shift linkage,ecu or motor mounts and all that other stuff changed. Any input from someone who currently owns a turbo A6 would be great.
Old Aug 4, 2008 | 10:37 AM
89s1's Avatar
You're fooling yourself if you think those 20 year old motor mounts are going to do any good restraining a turbo a6. You will need stiffened motor mounts either way ideally.
Old Aug 4, 2008 | 11:28 AM
whiteknightef's Avatar
I have run an a6 turbo for a few years. I find I get a better tune out of the newer non vtec heads than the a6 head. The blocks are great, I have had no problems at 10 psi even. I have been keeping mine at or around 225-230 hp just to be safe. I am running a y7 head, z6 intake mani, and obd1 conversion. runs great. I will tell you right now it takes my s2000 any day of the week. Im going to add a 1.7 crank and 135mm forged rods to get some more torque. I run a t3/t4 garret combo with a sequencial blowoff, custom piping and ebay intercooler.
Old Aug 4, 2008 | 02:31 PM
redef90si's Avatar
Default Re: d16a6-T or b18a? (whiteknightef)
in regards to the motor mounts i'll just put in polyurthene inserts,I have a extra head i can slowly build as a back up but i've heard similar things said about the a6 heads.Roughly what did your turbo setup cost?
Old Aug 4, 2008 | 02:40 PM
wagalude's Avatar
in the latest project car mag the junkyard turboed a d16 and beat a B16 with it
Old Aug 4, 2008 | 03:33 PM
redef90si's Avatar
Default Re: d16a6-T or b18a? (wagalude)
i hope a turbo'd beats a b16
Old Aug 4, 2008 | 03:37 PM
dr_latino999's Avatar
If you build it right, be prepared to drop some serious cash. On my D16Z6 block I'm almost at 3,000, so if you ever plan on building any motor pick wisely as building them costs about the same, the potential differences are the dividing line.
Old Aug 4, 2008 | 03:45 PM
redef90si's Avatar
Default Re: d16a6-T or b18a? (dr_latino999)
this will be a lower budget turbo build over 6months to a year.like i said i'm keeping the block stock and just running low psi.
Old Aug 4, 2008 | 03:52 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
im not running a a6 but a dohc zc and with a simple setup im putting down 120whp more than an LS.
Old Aug 4, 2008 | 03:57 PM
redef90si's Avatar
Default Re: (jdm_dc_fan)
wow sounds like fun if your ever out towards beliingham i'd love to se it
Old Aug 4, 2008 | 05:19 PM
single cam fan's Avatar
Default Re: (redef90si)
My turbo a6 smoked the sh$t out of my homeboys supercharged gsr in a del sol and it was tuned, at like 210 to the wheels. I put 2 cars on his a$$.
90 si hatchback
MODS
d16a6
scat rods
vitara pistons
stock rebuilt head
cc clutch
walbro 255 fuel pump
450 dsm injectors
turbo smart boost controller
cometic headgasket
arp headstuds
t3/t4 .63 hotside .50 cold
ETD traction bar
Car made 240 on 14psi
Old Aug 4, 2008 | 05:57 PM
redef90si's Avatar
Default Re: (single cam fan)
nice number single cam glad to here a few others have faith in the a6 lol
adam00
Aug 14, 2008 10:09 PM
Not_So_JDM
Jun 22, 2007 11:09 PM
Guru Designs
Aug 19, 2005 10:28 AM
sit220
Jun 18, 2004 05:14 AM
vod
Jan 12, 2004 01:21 PM
