distributor question
Old Aug 3, 2008 | 07:46 PM
MyEfSi2Slow's Avatar
Default distributor question
how to wire it up, help
Old Aug 3, 2008 | 08:58 PM
rebar71's Avatar
I'm feeling generous...
Old Aug 4, 2008 | 08:15 AM
Default Re: distributor question (MyEfSi2Slow)
well its wired up correctly, but its still throwing code 9, ive herd its my cyp sensor, but iono where that is, and ive also herd its my dizzy but ijust got a new one put in so iono what it is
Old Aug 4, 2008 | 08:25 AM
rebar71's Avatar
Check this thread over at TI and see if it helps you...
http://www.team-integra.net/fo...Topic
Old Aug 4, 2008 | 11:33 AM
Default Re: (rebar71)
ok now i gota real problem, i took off my dizzy cap to see if it was messed up, its fine, and i go to put it back on and now it idle and runs like crap, it pudders real bad once i give it gas, can anyone help, this sucks big time
Old Aug 4, 2008 | 07:55 PM
rebar71's Avatar
maybe your wires and/or plugs are shot...? Or maybe the dizzy is rotated too far one way or the other causing your timing to be way off...?
Seriously - there's not a lot of info to go on here. I'm just kinda shooting down the alley you started with.
Modified by rebar71 at 10:39 PM 8/4/2008
Old Aug 4, 2008 | 07:59 PM
Ricextacy's Avatar
this one helped me out.
Old Aug 6, 2008 | 02:40 PM
ha thanks guys, i had the 3rd and 4th switched up, well the ecu is still tellin me CYP is messed up, does anyone know what this means?
Old Aug 6, 2008 | 03:39 PM
JDM_320R's Avatar
did you check if the rotor is in good condition?
reset the ECU
Old Aug 7, 2008 | 09:47 AM
Default Re: distributor question (JDM_320R)
yep rotor is brand new, how do i reset the ecu? people just told me to just take the ecu fuse and the clock fuse and leave it like that for 10 mins and it should reset? is that right?
Old Aug 7, 2008 | 10:10 AM
rebar71's Avatar
Check the lkink<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyEfSi2Slow &raquo;</TD></TR><TR><TD CLASS="quote">ha thanks guys, i had the 3rd and 4th switched up, well the ecu is still tellin me CYP is messed up, does anyone know what this means?</TD></TR></TABLE>
Check the link I posted above regarding the CEL code on the CYP.
Old Aug 9, 2008 | 09:28 AM
Default Re: distributor question (rebar71)
hey thanks alot rebar, i reseted my ecu and it hasnt came on since, much props
meallout
Mar 19, 2009 11:01 AM
daklown
15
Jun 5, 2005 10:37 AM
civicboisi
14
Dec 20, 2004 09:08 PM
ellinikosmagas
Dec 30, 2002 09:54 AM
