Will an '06 - '08 Civic Si transmission bolt up and function properly in an '05 RSX Type S?
Old Aug 3, 2008 | 07:31 PM
weavertime1's Avatar
Default Will an '06 - '08 Civic Si transmission bolt up and function properly in an '05 RSX Type S?
I would like LSD and I found a few '06 and up civic Si transmissions around, so i wondered if this is as straight forward as i think it would be into my '05 RSX S? Thanks!
Old Aug 4, 2008 | 08:15 AM
DeDonDeRosa's Avatar
Default Re: Will an '06 - '08 Civic Si transmission bolt up and function properly in an '05 RSX Type S? (wea
yea i dont see why not.
Old Aug 4, 2008 | 08:24 AM
Me either, and I just wanted some opinons, and maybe someone who has done it, just to make sure. Thanks for the opinion!
Old Aug 4, 2008 | 08:43 AM
845_dapek's Avatar
no it wont
Old Aug 4, 2008 | 09:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 845_dapek &raquo;</TD></TR><TR><TD CLASS="quote">no it wont </TD></TR></TABLE>
Do you have any information regarding that answer?
Old Aug 4, 2008 | 09:30 AM
845_dapek's Avatar
the gears would sit differently then your 05 tranny
Old Aug 4, 2008 | 10:13 AM
I just want to completely swap the whole transmission to an '06 to '08, not just the LSD. Any idea based on that?
Old Aug 5, 2008 | 09:56 AM
archull's Avatar
The 06'+ Si tranny will not bolt up. The casing has different mounts and bolt pattern. It will not bolt up at all. You may be able to swap the gears from the Si tranny to the type-s Tranny though
Old Aug 5, 2008 | 03:21 PM
Ok so I guess I am looking at installing an LSD, or finding a JDM DC5 type R trans correct?
Old Aug 5, 2008 | 03:47 PM
_BEN_'s Avatar
Your talking about swapping the whole transmission correct?
A certain K20A forum has a pretty good write up on this. It's in the transmission section.
Depending on the year you will have to sort out some issues with the VSS and the shift linkage. But I think because you have an '05 you should be good.
Modified by _BEN_ at 5:51 PM 8/5/2008
Old Aug 5, 2008 | 07:25 PM
Oh, so it will work!
Old Aug 5, 2008 | 08:46 PM
archull's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weavertime1 &raquo;</TD></TR><TR><TD CLASS="quote">Oh, so it will work!</TD></TR></TABLE>
The internals will work but not the casing
Old Aug 6, 2008 | 07:15 AM
alright, so I am just gonna look into this a bit deeper. Thanks for the help!
Old Aug 7, 2008 | 08:25 AM
nahonda04's Avatar
Surje.motorsports
you can get a type-r LSD on ebay from japan for $500
modulo_s
Nov 5, 2009 10:44 AM
bigfigman
Honda Civic (2006 - 2015)
16
Jan 29, 2007 02:28 PM
dc506
Aug 14, 2006 04:00 PM
Skunk91
May 5, 2006 06:58 PM
94HatchbackSI
10
Sep 28, 2004 04:03 PM
