Engine Build
Old Aug 3, 2008 | 04:56 PM
hondateg10's Avatar
From: Somewhere in the United States, united states
Default Engine Build
I would like to build a Engine. Not really sure where to start and what i need. I have 2 B ser blocks. One is an LS and the other is a B16.
I would like to build an all motor for now. The motor would be going into a 95 EG hatch.
Im kinda new and need some help on what i would need to build a good motor. name brands on the parts and about the price for the parts.
Thanks for your help
Old Aug 3, 2008 | 05:55 PM
2wheelhunter's Avatar
Default Re: Engine Build (hondateg10)
how much are you looking at spending.. just look at other people's setups and take the best of the best or if your going budget then take the ls block and crank and put the b16 rods (and rod bolts) in it and buy a set of ITR pistons and throw a vtec head on it.. it should be around 175ish whp
Old Aug 4, 2008 | 05:15 AM
hondateg10's Avatar
Default Re: Engine Build (2wheelhunter)
I really not looking at a budget right now. Im just gonna do a little at a time for now. I will probably start off buy using the LS block and taking it to a machine shop. But what to bore it out to? not sure. Then I will probably take the B16 head and get it tested.
But as for all the internals what you use and what i need is my main Question? I want it to be reliable.
Old Aug 4, 2008 | 05:48 AM
hondateg10's Avatar
or would it be better to build my B16?
trever0x17
May 19, 2010 10:52 AM
lilvietboy
Feb 4, 2009 04:31 PM
skillzhb
Jan 10, 2009 10:40 PM
vestalfootball72
Oct 5, 2006 08:55 PM
wickedracer
Feb 23, 2003 12:58 PM
