smoking problems?
Old Aug 3, 2008 | 04:31 PM
BadMaka's Avatar
Default smoking problems?
motor smokes a lot it burns oil going down hill in gear, then I push the pedal then it dumps smoke out of my exhaust but it doesnt seem i lost any power, any suggestions?
Old Aug 3, 2008 | 04:53 PM
BlueIntegraBoy's Avatar
Default Re: smoking problems? (BadMaka)
Rings. Does it smoke too while decelerating? This is how my old motor was.
But to know for sure, you will need to do a leakdown test.
Old Aug 3, 2008 | 05:20 PM
BadMaka's Avatar
Default Re: smoking problems? (BlueIntegraBoy)
ya it does after hitting the gas, but i put it in neutral when decelarating so it doesnt put out smoke.
Old Aug 3, 2008 | 06:52 PM
robfrmny21's Avatar
need new piston rings my friend
Old Aug 3, 2008 | 07:03 PM
BadMaka's Avatar
Default Re: (robfrmny21)
just seeing if it was something else rather than the rings but i already have the new ring and pistons
Old Aug 4, 2008 | 05:47 AM
walker111's Avatar
Default Re: (BadMaka)
Decl valve seals, accel rings.
Old Aug 4, 2008 | 07:01 PM
Chris F's Avatar
Default Re: (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Decl valve seals, accel rings.</TD></TR></TABLE>
Yeah, sounds like he described exactly valve seals. The oil builds up under the vacuum of decel getting sucked in from the valve seals, and then burns off when he hits the gas.
-Chris
Old Aug 4, 2008 | 07:47 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
-Chris
it could be valve seals or rings, my old c5 burnt oil like that and i replaced the valve seals only to find out the oil control rings were messed up, which meant i still had good compression just burned alot of oil
Old Aug 4, 2008 | 11:47 PM
veilsides2000's Avatar
Maybe u drive the **** out of it?
Old Aug 5, 2008 | 02:31 PM
typeR#0427's Avatar
Default Re: (EARLdaSQUIRREL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL &raquo;</TD></TR><TR><TD CLASS="quote">
it could be valve seals or rings, my old c5 burnt oil like that and i replaced the valve seals only to find out the oil control rings were messed up, which meant i still had good compression just burned alot of oil</TD></TR></TABLE>
My exact situation. I just check the oil level, <U>ALOT</U>
socialistic
18
Jul 1, 2011 04:31 PM
EK FLY
Jul 1, 2007 02:52 PM
H9Omega
16
Dec 14, 2006 06:28 PM
DSRxMilogen
Mar 28, 2005 07:24 PM
dstahl01
17
Feb 28, 2004 06:38 AM
