window goop
Old Aug 3, 2008 | 01:29 PM
lokuntry's Avatar
Default window goop
Bought a 1998 EX coupe this summer, everything good Except the drivers window gets this goop on it-like stringy rotten rubber bands-when I drop it down part way. The rubbery smear is tough to get off with Windex, and it comes right back whenever I drop the window. Today I noticed the passenger window is getting the same problem at the front end of the window. I figure I'll take the door panel off for a look, but does anybody know what this is?
Old Aug 3, 2008 | 03:39 PM
rarrior23's Avatar
Default Re: window goop (lokuntry)
Sounds like window tint glue leftover after someone took off their tint. I have the same thing on my windows. Goo Gone is supposed to get rid of it but it didn't work for me. Just take a razor blade and scrape it off until the glass is smooth, that should work.
Old Aug 3, 2008 | 03:55 PM
TylerB's Avatar
Default Re: window goop (rarrior23)
Make sure to wet the window while you are doing it.
rarrior23's Avatar
Default Re: window goop (TylerB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TylerB &raquo;</TD></TR><TR><TD CLASS="quote">Make sure to wet the window while you are doing it.</TD></TR></TABLE>
Wet it down with water then spray it with the Goo Gone?
Old Aug 3, 2008 | 03:59 PM
TylerB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rarrior23 &raquo;</TD></TR><TR><TD CLASS="quote">
Wet it down with water then spray it with the Goo Gone?</TD></TR></TABLE>
No sorry, if you are going to use a razor blade on your window, the window has to be wet. Otherwise it will scratch the **** out of it. I have always just used window cleaner. Just make sure you keep spraying and it stays wet. And keep the razor blade as straight as possible.
Old Aug 3, 2008 | 04:23 PM
lokuntry's Avatar
OH yeah-that must be it, but I never woulda thought of it.
Thanks, guys.
Nealva
Oct 12, 2016 11:41 AM
crxaddikt
17
Jan 13, 2015 04:04 AM
99exT
May 2, 2011 06:16 AM
george34
Sep 27, 2006 07:23 PM
Sean @ ESG
14
Sep 9, 2005 09:21 PM
