Can you remove an axle WITHOUT separating the lower ball joint?
Old Aug 3, 2008 | 08:58 AM
C_Rock77's Avatar
Default Can you remove an axle WITHOUT separating the lower ball joint?
I need to replace an axle, and when I went to separate the lower ball joint, the castle nut won't come off. It's backed down to the bottom of that stud, but won't come off. It's looking like it may have been cross-threaded b/c the stud spins with the nut when you try to do anything.
So, is there a way to remove the axle w/o separating that joint?
Also...if you have any suggestions on how to get that damn nut off w/o having to replace the ball joint, that would also be appreciated.
Old Aug 3, 2008 | 09:30 AM
lsvtecboi'95's Avatar
yea everytime i did it i didnt take the ball joint out just remove the lower control arm and swing the rotor all the way to one side... there should be enough play in the axle to allow it to fit
Old Aug 3, 2008 | 10:05 AM
JDMguy88's Avatar
Default Re: Can you remove an axle WITHOUT separating the lower ball joint? (C_Rock77)
to keep the stud from spinning with the nut you hold the stud with vice grips while turning the castle nut, thats what Ive done when that happens to me, its not uncommon
Old Aug 3, 2008 | 11:30 AM
if you use vice grips you could mess up the threads on the joint and that means $$$$ to get a new one...
Old Aug 3, 2008 | 01:38 PM
RA429's Avatar
yes it can be done without removing the ball joint. just disconnect everything so you can swing it out far enough, you might also have to disconnect the sway bar endlinks
Old Aug 3, 2008 | 02:38 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Why not just separate the upper balljoint? Works fine that way too.
Old Aug 3, 2008 | 04:06 PM
JDMguy88's Avatar
Default Re: (lsvtecboi'95)
so put duct tape around the vice grips so they dont damage the threads
Old Aug 3, 2008 | 05:25 PM
nb0's Avatar
nb0
Default Re: (JDMguy88)
I have gone through pain twice. Separating the lower ball joint with a pickle fork will bust the ball joint. After removing the castle nut and placing a jack under the threads and jacking it up will crush the threads. Don't mess with the lower ball joint area.
Disconnect everything so you can swing it out.
Old Aug 3, 2008 | 08:36 PM
C_Rock77's Avatar
Default Re: Can you remove an axle WITHOUT separating the lower ball joint? (ngswimmer08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngswimmer08 &raquo;</TD></TR><TR><TD CLASS="quote">yes it can be done without removing the ball joint. just disconnect everything so you can swing it out far enough, you might also have to disconnect the sway bar endlinks</TD></TR></TABLE>
Is the swaybar under tension just bolted to the car?
Old Aug 5, 2008 | 09:30 PM
nb0's Avatar
nb0
http://www.hondapartsunlimited...dIrno=
Old Aug 6, 2008 | 03:32 AM
turbodcxbro's Avatar
Default Re: (nb0)
Swaybar is just bolt on, might spring up a little on ya depending on how far you have the car jacked up but nothing thats going to hurt you.
I've never removed the lower balljoint to replace any axle, no reason too.
Old Aug 27, 2008 | 11:19 AM
HeikDiesel's Avatar
Default Re: Can you remove an axle WITHOUT separating the lower ball joint? (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">Why not just separate the upper balljoint? Works fine that way too.</TD></TR></TABLE>
Thats how I've always done it
White_EG1
22
May 21, 2018 10:20 AM
Alcatrax30
Nov 9, 2014 05:38 AM
B18CYAAA
Nov 25, 2006 01:22 PM
B18CYAAA
Oct 25, 2006 02:29 PM
VisualAutoMotoring
Oct 11, 2003 04:08 PM
