My first shot at a catch can.
Old Aug 3, 2008 | 02:40 AM
vectorsolid's Avatar
Default My first shot at a catch can.
Figured it was about time I tried to build one of these. Never built one before but seen enough of them in pictures. I incorporated a bracket to hold my fuel filter. I don't build much stuff this big. I piddle with aluminum. I was amazed how much heat I had to get into it to get a puddle moving. I played with 120hz on the fittings and 200hz on the seams. I was thinking it would get me a bit more penetration on a butt weld. Not sure... I'm still learning. But I'm having a good time.
Started with 1/16 tungsten (what I normally just leave in the torch), burned it to a crisp trying to get a puddle moving at 100 amps. Put in 3/32 tungsten and turned it up to 125 and it was better. Main body of the tank is 3x6 inches. Big fittings are 10 -AN, and the drain is a 6 -AN
I offset the fittings because I like the look of braided line. Seems a shame to stack them on top of each other when you can see them both when they're offset.
Modified by vectorsolid at 3:51 AM 8/3/2008
Modified by vectorsolid at 3:56 AM 8/3/2008
Old Aug 3, 2008 | 08:10 AM
TigWiz's Avatar
Default Re: My first shot at a catch can. (vectorsolid)
That looks really good, especially for a first try. I'd put it into my car
Old Aug 3, 2008 | 04:13 PM
EJ6JON's Avatar
wow looks great i would use it on my car also!
Old Aug 3, 2008 | 09:12 PM
Nick Z32's Avatar
Default daymm
all thouse EARLS fitting musta been 3 times the cost of that it took to make that catch can huh
Old Aug 3, 2008 | 10:11 PM
Default Re: daymm (Nick Z32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick Z32 &raquo;</TD></TR><TR><TD CLASS="quote">all thouse EARLS fitting musta been 3 times the cost of that it took to make that catch can huh </TD></TR></TABLE>
If they were Earls, pretty likely. Summit has the best bang for the buck on fittings, Summit branded. About 1/2 the price.
Old Aug 3, 2008 | 10:17 PM
deryck324's Avatar
i like the fuel filter bracket attached to it
Old Aug 4, 2008 | 04:05 AM
b16a1eg6's Avatar
Default Re: (deryck324)
https://honda-tech.com/zerothread?id=2347697
Old Aug 4, 2008 | 04:16 AM
Mikey3000's Avatar
very nice! do you know what its capacity is? 1.5 qt?
Old Aug 4, 2008 | 05:37 AM
siblues's Avatar
Default Re: My first shot at a catch can. (Mikey3000)
Very nice can man looks very well built
Old Aug 4, 2008 | 08:24 AM
crx303's Avatar
Nice
Old Aug 4, 2008 | 12:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">very nice! do you know what its capacity is? 1.5 qt?</TD></TR></TABLE>
Best case scenario, 54 cubic inches. Looks like it's just short of a liter or 1 quart. I'm of the mind that seeing as how my little air filter isn't wringing wet with oil, and was my only crankcase ventilation, it's not likely this can will ever see anything in it. Time will tell.
Old Aug 4, 2008 | 01:15 PM
mike93eh2's Avatar
doesnt everyone say those earls fuel filters are bad news?
Old Aug 4, 2008 | 02:31 PM
dmotoguy's Avatar
Default Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">doesnt everyone say those earls fuel filters are bad news?</TD></TR></TABLE>
eek? what?
Old Aug 4, 2008 | 02:32 PM
mike93eh2's Avatar
Default Re: (dmotoguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy &raquo;</TD></TR><TR><TD CLASS="quote">
eek? what?</TD></TR></TABLE>
yup. do some research..
Old Aug 4, 2008 | 02:39 PM
comp's Avatar
looks good,,how did you set up in internal baffle ???
Old Aug 4, 2008 | 04:19 PM
Default Re: My first shot at a catch can. (comp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by comp &raquo;</TD></TR><TR><TD CLASS="quote">looks good,,how did you set up in internal baffle ???</TD></TR></TABLE>
Didn't set up an internal baffle. I'm of the mind that if my little air filter wasn't wringing wet with oil, there's no way I'm forcing fluid down a line that's 6 times bigger with any kind of velocity that would require a baffle. A baffle would be in place to slow movement of something, in this case, either oil or air pressure. If you could hang that air filter directly off the valve cover without it leaking oil (as it does now with a MUCH smaller and higher velocity hole) and there is no problem, I don't foresee a problem with no baffle.
That said, I did take the tube that the air filter mounts to, and mount it lower than the first -AN fitting, as a baffle of sorts.
My personal, opinion is that a baffle is not needed on my car. If I'm wrong, I'll build another with a baffle. Ain't nothing but some more welding.
Old Aug 4, 2008 | 11:45 PM
Here's how it looks with the intake piping.
Old Aug 6, 2008 | 01:32 PM
TS4L's Avatar
Default Re: (vectorsolid)
The baffle is a really good idea. If your motor is fresh and has less tha 5% leakdown you really won't get much blow by, but on a motor with some miles on it you'll get q bit. Especially once you add boost to the equation. A lot of catch cans aren't baffled and still work ok. You can do what lots of people do and stuff some filler in there to knock the oil out of the air. I'm not a fan of that technique but it works for some. I'd leave it and if and when you begin to get blow by I'd look at adding the baffle.
Old Aug 6, 2008 | 10:01 PM
Road_Runner's Avatar
nice!!! when is it for sale??
Old Aug 6, 2008 | 10:30 PM
Default Re: (Road_Runner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Road_Runner &raquo;</TD></TR><TR><TD CLASS="quote">nice!!! when is it for sale??</TD></TR></TABLE>
Never. Takes to long... ...lol... Almost makes that $200 for a can seem like a good deal. First one is the worst. I'd order material dimensioned if I did it again, save that time I spent hand fitting things.
Old Aug 10, 2008 | 11:55 AM
BoosTT's Avatar
looks good, I just got a bunch of work done on one for myself. 3" diameter tube about 6" tall, used 2 -10 AN's and theres a small baffle inside the can directly over the -10 bungs. The rest of the can is stuffed with stainless steel wool. Need to weld a fitting for a breather, and one for a drain still.
Summit fittings are def. the way to go.
Old Aug 15, 2008 | 04:57 PM
Globe1896's Avatar
Default Re: (BoosTT)
Areoquip fittings are the way to go
Old Aug 15, 2008 | 09:39 PM
JDMCRX's Avatar
Default Re: (Globe1896)
Nice wish my welding was that good lol.
Old Aug 16, 2008 | 01:46 PM
honduh_head's Avatar
nice work
Old Aug 19, 2008 | 12:47 AM
Default Re: (honduh_head)
Thanks for all the kind words guys.
