Help Building a Turbo GSR MOTOR Green Horn!!!
Old Aug 2, 2008 | 02:20 PM
mantenuto320's Avatar
Default HELP BUILDING A TURBO GSR MOTOR GRREN HORN!!!
HI THERE I JUST GOT A 96 GSR AND I WANT TO BUILD A TURBO MOTOR. HOWEVER I HAVE NO IDEA WHERE TO START WHAT SHOULD I DO TO MY MOTOR TO GET IT STRONG ENOUGH FOR A TURBO, I WANT TO BUILD IT THE RIGHT WAY FROM THE BEGINNING SO THAT I DONT HAVE TO GO BACK AND DO IT OVER.
Old Aug 2, 2008 | 02:49 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: HELP BUILDING A TURBO GSR MOTOR GRREN HORN!!! (mantenuto320)
DON"T TYPE LIKE THIS.
You need to read much in the forced induction forum and establish your goals to determine the pathway to successfully arrive there.
Old Aug 2, 2008 | 08:01 PM
Spody02's Avatar
Default Re: HELP BUILDING A TURBO GSR MOTOR GRREN HORN!!! (Dogginator)
low comp pistons
stronger sleeves
stronger rods
new valve train
turbo cams
victor x manifold
then
sick turbo setup
searching is your friend
Old Aug 2, 2008 | 08:30 PM
Rickdrizzle's Avatar
Default Re: HELP BUILDING A TURBO GSR MOTOR GRREN HORN!!! (Spody02)
Generally the gsr motors can handle up to 330whp safely from what I read. If your motor has a crapload of miles, just do a typical engine rebuild and replace the rings, bearings, pumps, etc. If you wanna make 400whp, a simple rod+piston combo can help achieve it. And as always, tuning is essential.
Old Mar 25, 2009 | 02:52 PM
hatchtegman's Avatar
Default Re: Help Building a Turbo GSR MOTOR Green Horn!!!
if you are going to tear it down to do a typical rebuild.. you midaswell do a sleeve job resleeve it with darton mid sleeves or golden eagle.
while that is being done. buy parts and then install all them... check on this site for deals and also on yoparts.com is a nice site if you need cheap name brand stuff. expect to pay 950-1200 for sleeves.. before you ahve that done think about buying low compression pistons i recommend only name brand nothing ebay junk. and when you have the sleeves done send the pistons along. good luck.
B20vtcdrewskee
Apr 10, 2010 06:11 PM
Dukie432
80
Dec 24, 2008 04:08 AM
mantenuto320
Aug 1, 2008 08:34 PM
ctownintegra
Mar 2, 2005 09:32 PM
ITSTOCK
Apr 6, 2004 05:33 AM
